[Reference] Nichia E17A/E21A (2000K - 6500K, R9050/R9080, color) CCT and tint shots
So a quad e17a is about the size of an XP-G LED, and quad E21a is about the size of an XM-L LED.
Would you say the quad e17a will have about 40% more throw than the e21a at the same power setting?
Tint vs. current on the same 6500K version. Fast sweep with only 3 seconds spent on each step.
CRI data at a couple currents
100mA
500mA
1000mA
:laughing: Hahahaha, thanks Maukka. Your post makes me giggles. The color swings for 3 steps R9080 is the tightest.
[Clemence]
I tested only 2000k and e17 has a very low lm/w. And, generally. you get same picture in narrow optic (a smalled spot and seeming increase of range). A only advantage of e17 series is a rosy tint at a lower current than e21
Thanks for the information. Could you tell me what optics have you used?
XP 20 mm x 5 degree with custom matted #320 sand and slightly cleared dichloroethane. Bottom of lens is cutted off to 0.3 mm ([GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)] - #475 by clemence GB 351D closed. - #100 by Bob_McBob). And i will be compared parallel 2000+3000k with 10x30 elliptical lens. I have it in e21 and, for me, throw is low as outdoor light. All optics is yajiamei
So if I am understanding you right your are using a lens like this(Page Not Found - Aliexpress.com)? Is it a multiemitter setup(VR16SP4) or single emitter setup?
Yes this lens. Maximum 2xe21 on vr16s1 (hole dia 4.8 mm). Very carefully when installing the lens, damage to the phosphor is possible
An quad system (vr16sp4) i do not use because i got problems with focusing and final output. My working hl have 2x 5000k with https://www.aliexpress.com/item/1281151114.html
Clemence,
Have you played with using the Green/Lime E17A in a tint mixing array in order to better track the BBL?
Has anyone gotten an E17a quadrix to fit in a 1 x AA/14500. Since I missed the Jetusolis GB, I want to make 3 Tool AA Quadrix setups - 1 each at 2000K, 4000K, and 5700K. I could probably file down a 16mm E17a board to 14mm but I’m afraid to damage the E21a emitters.
I have quite a few 219b R9080s in different tints (3000K, 3500K, 4000K, and 4500K)so that’s the backup plan but I love the range of tints and the ability to mix with the Quadrix setup.
Filing down a 16mm seems like it should be a reasonable solution, as long as you’re careful not to touch the delicate phosphor coating on the emitters while handling it.
I also remember Clemence saying something about being careful not to damage the ceramic insulating layers when drilling. I’d suggested making your filing motion mainly around the circumference, rather than up and and down.
1 x E21A would be an option, except the 10mm single emitter boards are out of stock, and if you’re using a 14500, that might be a bit much for the emitter.
Maukka, have you done this same output/voltage sweep on a 9080 version e17a yet? Is it possible for you to do one if not? I’m very curious how the 9080 Vf and efficacy look.
Thanks!
Clemence lists all of his E17A’s as R9080 except the 2000K and 2200K. But even the 2000K actually tested at R9080.
The voltage curves should be generally similar, although it is possible they are of different bins, and within a voltage bin, there can hypothetically be up to 0.2V difference at 350mA.
Output can be estimated by multiplying by the ratio of the output bins, which are given as BXX for the E17A.
So to estimate the 4000K (B11) at a given current, take the output of the 6500K (B12) and multiply it by 11/12. For the 2000K, multiply it by 8/12.
hello, when will triple e21a for fw3a be available?
:wink:
I am also interested in this. With the new Lume1 driver on the way, I would really like to put some E21a emitters in my fw3b to make it match my brass d4v2.
Anyone in the US have a single E21A or E17A they would be willing to put in an envelope and send (will pay obv).
I want to to try it in this Olight:
yes
pm me your address :slight_smile:
Can you please tell me if this mixture of diodes will be pinker than nichia 219B sw45k?
Thank.
