You have to use twist it on and off to cause this. And some dirt or connectivity issue at the same time. This is not an expected usage, so there’s really no worry here (unless you have a need to use twist on or off frequently as cut off, like me).
May be a loose retaining ring… Mine have all had some initial issues with the ring being loose/off center, or the interior tube not meeting the intended contact point. Could also be some oxidation on the contact points… a q-tip with some rubbing alcohol may clear that up if it is an issue.
I’m using the 5/32 o-ring and it’s great. However, the o-ring presents a little challenge. The tail cap must be totally tight. If it’s a little loose? You get weird shut-off events. It doesn’t take much loosening for it to happen either.
Got my little FW3A parts parcel from Neal’s Gadgets. Picked up an 18350 tube. Lanyard ring. SS bezel. And aqua GITD.
Well, I have to say I’m a bit disappointed by that aqua. While it’s a nice color, it’s noticeably weaker than the green AND it fades off faster. It bothers me enough that I’m going to try a few timing tests. At least it comes in a nice twist top round plastic container.
I just got around to it tonight. TOTALLY TRANSFORMATIONAL! Excellent idea, and takes less than two minutes. Thanks Jared!
I can see trying a 5/32, or maybe experimenting a little, because it is a bit stiff now, but it is great, and SO MUCH BETTER. I really got tired of the four click routine all the time, and this light did turn on far too easily. I bought three 008 rings at the hardware store, and it is for sure the best 90 cents I’ve ever spent.
I first tried the 3/16” o-ring and button was way too firm for my liking. Exceeded stiffness beyond what I’d consider normal. I found 5/32” works much better. The only drawback is that it does create some switch noise (the OEM nubbin has hardly any sound at all, at least with my early production FW3A). Not anything unusual and still quieter than a clicky switch or the 3/16” o-ring.
I used a spare mechanical keyboard o-ring I had, which was not quite “to spec” but close.
Thoughts after carrying it some: Completely different light. Not a single accidental activation since the switch (pardon the pun). The button is a wee bit mushy now, but the functionality is incredible. This is how the FW3A always should have been. It instantly jumped up to be one of my leading pocket-time lights, especially after also going to the throwiest Carclo triple optic.
Just did the o-ring mod also using a generic keyboard keycap sized o-ring and did a very [un]scientific method of measuring switch force: used a kitchen scale and watched how much weight in grams was needed to actuate the switch.
Three candidates: Gen1 grey FW3A without switch retaining ring, blue FW3A with switch retaining ring but similar switch feel with the o-ring mod, and a purple FW3A with switch retaining ring and a much stiffer stock switch which must be an improved switch design.
Actuation force, approximated:
Grey FW3A with light switch: ~300g
Purple FW3A with stiffer switch: ~600g
Blue FW3A with light switch and o-ring mod: ~700g
One thing of note is the purple FW3A’s stock stiff switch is much more satisfying to click than the modded blue one, there’s a bit of dead travel in the o-ring switch without the nubbin’ leading to an initially mushy feel like others have said, but it’s definitely an improvement.
This is an easy hardware fix instead of modifying the firmware to make a software solution.
The firmware “fix” I did was to replace the lockout second click’s default value of using the second ramp’s floor for momentary, with the value used for manual memory which I use on all my Anduril lights. So 2H gave me a momentary function for the level of light set to manual memory while locked out, useful if light was only needed for a couple seconds.
I swapped the leds to SST20 3500K, really nice tint. But I am getting short somewhere, there is only turbo. I was checking the both sides of driver under stereomicroscope and didn ´t find anything. First I tested leds with a power supply on low miliamps and everything worked as expected. I really have to figure this out :D. Maybe some driver components are touching a flashlight body, don´t know.
This happened to me on my polished FW3T after I tried swapping in the optics and the new optic pressed too firmly against the emitter.
The problem wasn’t the driver. Rather it was a bad solder job under one of the LEDs. There was a short between the negative contact pad of one LED and the center ground pad. You can test for this as follows:
remove the star from the light
connect one probe from your DMM to the negative driver wire pad on the top of the star.
connect the other probe from your DMM to the side or bottom of the star.
If you get a connection, then you have a short. This short causes the light to bypass the driver completely. The only output you get is max turbo and the switch does nothing. It will turn on in max turbo the instant the battery tube is halfway screwed in.
If you have the same problem, the solution is to reflow the LEDs and check the solder under each one. I did that on mine and it completely fixed the problem.
When you assemble the light, is it instantly turbo or does it ramp up first? Mine did the second after I dis- and re-assembled the switch, and I had to take it all apart and re-assemble carefully according to… There’s instructions somewhere, let me re-find them… The FW3A useful information thread
Firelight2, you were right, I resoldered the leds and problem was solved. I should check if leds are grounded sooner with a power supply . Thanks for help, as always nice advices here.
