I just want to say Mr. Hank Wang you are awesome. I’ve got a D4V2, D4V2 TI, D1S, and now this ridiculously awesome K1. You really make this hobby more enjoyable with all these lights that perform without breaking the bank.
Thanks for the video. I’m not educated enough to speak German, unfortunately. Which was the flashlight on the Left in the white wall testing? Could you tell the difference in the spot brightness at about 20’ between the 2 lights outdoors? Thanks.
I have a question about battery choice for the K1 W1. In one place early in the thread it was reported that a battery capable of outputting more amps would have the extra amps converted to heat ad so be wasted. In another comment it said that a higher amp battery would be able to hold turbo longer.
Is it both?
Also, since the W1 uses 3 A less on Turbo it should have a much longer run time, right? Or does the extra power just go to heat? Am I missing something?
Bottom line:
What battery is best for the W1 version which will be used in the upper 1/3rd of the power range for 20-40 seconds then be off for minutes?
I think it is waterproof.
The o-ring on the FT03 tube does get fully compressed into the K1 head, but
the end of the battery tube can’t reach all the way to the driver board so I had to use a conductive spacer to complete the connection to the ground ring on the driver board.
The o-ring on the K1 tube does not get compressed on the FT03 head, because the tube contacts the driver before it is fully threaded into the head.
The threads on both lights match, but the threaded section on the K1 tube is longer than the threaded section on the F03 tube.
Also, the 26650 battery sets lower in the tube because of the spacer between the tube and head. The springs just barely make contact with the battery. A long, protected, 26650, or 21700 would work great.
This is just in theory since no measurement has been taken comparing side to side: Both drivers setting should draw about the same from the battery but while the W1 burns it off as heat W2 is being sent to the emitter resulting in extra lumens.
As the battery gets drained the voltage gap gets smaller and it becomes more efficient, with a high drain battery it will maintain turbo longer but overall runtime will be less. With a low drain cell it will continue to power the light much longer once it drops out of regulation when it doesn’t have to burn extra volt as heat so in the end you get a higher lumens-hour reading.
If you’re interested in highest output you should stick with high drain cells.
I would have thought that since the W1 driver is current limited to protect the White Flat then it only draws 5A from the cell, regardless of the capability of the cell. Or that’s been my experience in the last 1000 lights or so that I’ve dealt with…
The report that the extra amps will be converted to heat is not really correct but probably is referring to the fact that the higher amp cell can maintain a higher voltage at a given current (because of its lower IR) and that means extra voltage to be burned off by the driver. But the extra heat is probably not significant.
That 26650 tube looks good but not the best fitting as you said. I wonder will D4S or other 26650tube fit that intl-outdoor can just offer both? I would buy it.
Took my new K1 W1 for a 5 mile hike last night. It is really amazing to light up a house on the other side of the lake, over half a kilometer away.
Great for spotting Opossums, Nutra Rats, Herons, Ducks, etc. Really freaks them out when you hit them with that blinding beam
But, as was mentioned by others, this really is a specialized light, not at all practical for just walking around. It’s kind of an all or nothing type light.
So I just ordered another one with the XPL HI V2 5D
