Would someone please start BudgetDriverForum?
And convince HJK to publish driver reviews?
Or failing that, find where we can buy better drivers to swap into our amateur hobbyist toy flashlights?
EDIT: oops. He’s been reviewing drivers for quite a while:
You could make it beep when the battery gets low, like a smoke alarm.
Older people already know what to do when they hear that (call a young person to find the damned thing).
I liked djozz’s review of the SD03, particularly that it can easily be used with gloves on.
Is it moddable?
I’m always looking for lights I can mod to amber emitters, for myself and elderly friends whose sleep is easily disrupted by white lights.
This looks like an easily held onto shape and a simple UI.
I disagree. I have Olights that use their special magnetic dock. They are most inconvenient when you can’t find the dock or forget to take it along and then find yourself needing to scramble for a charger that you can borrow. Pretty much impossible at times. Whereas you can alomost certainly borrow a USB cord or if need be buy a USB cord at the grocery, the pharmavy, etc.
I agree that the charging should be via USB. However superior in design and function magnetic charging is, IMO that will not outweigh the convenience using a universal standard that is present in most homes. And a USB port is for most people self-explaining.
Btw, the fact that I do not find specialised aiding things for eldery people look particularly elegant has nothing to do with wether or not I respect eldery people.
I agree. The magnetic charging connector is not a good solution. I have two flashlights with magnetic connector for charging. Amutorch X9 and new Imalent DM21C. I wanted to buy the first version of the X9 with a standard USB connector, it was unfortunately sold out. I don’t use the magnetic charging cable for Amutorch at all. Charging the battery outside the flashlight. I would have to have at least three original cables. At home, in the car, at work. For older people, the USB C charging connector is best. It can be used from both sides.
Your idea is certainly right. The induction charging flashlight is sometimes sold by Lidl. But it produces it in large quantities, so the price is low. Sofirn cannot produce it in the same large series. The second argument is that seniors today often use mobile phones. Most use a standard USB interface for charging.
Yes, ‘even’ seniors use USB charging, of course.
Yes, USB-C would be best, as long as everything else would be USB-C too…
But by the time this light is on the market, USB-C will be more common, i guess.
Now we only have to figure out how the USB-C port will be accessible.
I.o.w., should there be some flap over it, or should it just be open?
Maybe just give it a rubber / silicone flap, which the end user can decide to remove altogether.
But an open port can be made waterproof too, but adds complexity to the production.
