ALL THINGS BUDGET KNIVES
Hmm, the NiteCore NTK05 looks like there’s room for a fatter blade. FreeMe has it at $25. Here’s a lock’s review.
Personally, I carry a MiniChamp :-), but have a Kershaw Cinder that I sometimes carry.
Thanks. :slight_smile:
I looked it up. It indeed looks like #10 would fit, though that’s not certain. Fasttech has them for only a slightly higher price w/out coupon; waiting for another 15-20% discount would drop the price to about $23-$24 shipped.
Considering that #10 blade is likely too small to be good for me anyway, that’s a little more expensive than I’d like….especially that I found other options:
http://www.aliexpress.com/item/4000306725903.html
$15, takes #22 blades.
81 mm is a little long considering the still-very-short blade. Well, most scalpel folders that I found are like that.
There are a few exceptions with non-standard blades, namely Havalon and Gerber. Though they produce only even bigger knives which are simply not good for me.
Look for local source for scalpel blades.
Many available.
Mike
If you're ignorant enough to use your knife for prying things, at least don't be surprised when you have bad results.
Knife blades aren't made for prying.
You're very likely to weaken or damage your blade if you ignorantly use it for prying.
And the weakening or damage may not be visible at first.
If you want to abuse your tools, be my guest, but don't tell me that knife blades are made for prying.
And if you decide to sell a tool that you abused, I hope you're honest enough to let the public know that you abused the tool in the past.
I’m sure they aren’t made to use as a screwdriver either, but guess what?
If the knife is the only tool I have available at that juncture it will be used for whatever it takes to get us out of a jam.
It’s not like these knives are family heirlooms, they are a tool and should be used and abused if needed, as such.
JMHO,
your’s sounds like it will vary and that’s cool.
Later,
Keith
Of course anyone can abuse their tools as they like.
Just admit that it IS abuse, and that the tools were never meant to be used that way.
When someone asks me to borrow my tools, I always ask what their intentions are because I don't want anyone to abuse my tools, myself included.
You might be surprised how many people think it's okay to pry something with a knife blade.
I think they outnumber the flat Earthers, which is kinda sad.
I’ve seen guys use Makita Impact Drivers as hammers becasue they were too lazy to go to the tool trailer so yeah some people do not care when the tool is not their’s.
Flat Earthers, Woo .
Now, what about the folks who believe in Hollow Earth?
We have a micro brewer in Oxford, PA called Hollow Earth brewing :slight_smile:
Later………………. gotta get back in the portal.
P.S. I don’t lend tools or pickup trucks/trailers , I’ll help you fix it with my tools though.
Small size makes this Titanium Alloy Utility Folding Knife (that comes with 10 blade replacement: Page Not Found - Aliexpress.com) very convenient as keyring blade:
Does the blade lock in place on those little scalpel-blade knives? If so, what type of lock?
A Useful Ütility” blade is the Browning. Heavy, and Heavy duty range.
3+in blade. THICK. 440c Steel. Rear lock. Basic. and cheap.
Minimum taper from top to bottom. and heel to tip of blade is useful for much more than peeling an apple etc.
Look for blades that carry their body thickness almost down to the tip. Stepping in just before then.
They have a backbone to lever with.
My old ENLAN $8 speshul, yrs ago. Is a good working blade.8cr13 steel.
Backbone carried almost down to the tip. Can do a lot of heavy work
IN IT’S SIZE RANGE. Plus serious sharpening, ahaving edge.
I carry a THICK shank, 9 in, flat blade screwdriver in sleeve in belt for serious levering items when out camping.
Takes no room. useful for many jobs. and handle has built in sockets for 3 x differing tips.
These toy folders are alright for cutting cardboard. Fuit etc.
But seriously.
Going camping/bush/Hunting.
Please take a fixed blade. 4 1\2 in plus, decent handle knife on your belt.
It’ll do all you want safely. Hold a good edge with a 6in, diamond steel in pocket
WITH the little toys in your pocket for smoko.
and you’ll come home with 8 fingers and 2 thumbs as a bonus.
Wow. It seams you really want to escalate. I don’t particularly appreciate anyone on the forum being called ignorant, but you’ve been here a while and maybe that kind of communication works for you. No worries. What’s obvious is that you’ve never been in a situation where you’ve had to use a tool for anything outside of it’s intended perimeters, and I really hope you never have to. However, that’s not been my life or my experience, and if it has to be done, the item’s resale value is really not what I’m thinking about. You clearly know about tools, so good luck with everything, and I hope this conversation can be over.
I like the Gerber EAB Lite for a utility knife, very slim & has a liner lock and pocket clip about $10 at walmart for black version.
Nicer look. I’m not all that enamored with the OEM “hippo” blade style.
Thanks!
I couldn’t rest and I modded my TwoSun TS70 too. :slight_smile: I took several pics about the process.
Before and after:
Hultafor makes a chisel knife you can probably pry with …
Absolutely love the TS16 in titanium!!! I have an order in for a TS165 with G-10 scales and a 14c28N blade. I will dye the G-10 golden yellow to contrast with the black detailing.
Excellent work! Thanks for the link to your progress photos. Send them to TwoSun and maybe they’ll make a new version in your honor. I don’t like their more unconventional blade design. Yours looks as it should have been.
The TS16 was a pleasent surprise for me too. Don’t forget to post pics about the result of the handle mod! :slight_smile:
Thank you! They can’t go wrong with a wharncliffe or a drop point blade but a new design could be a hit or miss.
Do you mean that there might be some blades more interesting than #10, #21, #22 that fit some of the mentioned handles or some other interesting handles?
Yeah, but my Ladybug is already a bit too small when I want to cut myself a loaf of bread. Or spread something on that loaf. When I think about having less than half the blade length I just don’t think it’s a good idea for me.
OTOH my knife is never scalpel-sharp. And sometimes when I don’t have time to sharpen it I am really disappointed with how it cuts. That’s why I’m considering compromising blade length even more.
Anyone could me recommend good seller for F95 in titanium?
Thx, Mike
