Thanks for pointing those out, raven5221. These may be a solution, although they will prove a challenge for assembly because the need to stick them inside the body hole instead of hoovering behind the hole. It depends on which direction the design goes if these are a good idea to recommend.
Have you ever tried to find a flashlight (without any glowing parts) on your night stand in the dark without knocking it over or onto the floor? I have, and then I have to try to find it on the floor in the dark.
A glowing diffuser is what I sometimes use, if the light itself doesn’t have any glowing parts.
It doesn’t take much glow or light to be seen in the dark next to you on a night stand.
Interested, I did a quick search for 18350, and got no hits. Would be much more interested if an 18350 tube is available, much more pocketable for me and grandma.
I’ll probably repeat a lot of what’s already been said but I’ll leave my few cents anyway.
As far as features go, I would prefer a TIR optic (but not too floody). With a high CRI emitter and an efficient driver. Detented off position would be lovely.
Strategically placed (thicc) knurling would be a good thing and the no-ano/SS ring should be slightly thicker than the rest of the body.
Suggested modes are fine, infinitely variable would be nice but not really necessary.
(Though if it ends up being variable then yes, please start from ~1lm but otherwise no.)
Regarding the charging port, like raven said, IPX7 and even IPX8 rated USB-C receptacles are a thing. The light needs to be designed around one and it needs to be implemented properly but I would pay a little bit extra for that.
Though that might be a bit too much to ask for in a ~20-25$ light, considering the BOM increase.
If someone wonders about the price, cheapest USB-C receptacles are ~0.1$ a piece in 100-1000+ quantities but if you add ingress protection then they start at around 1$.
Certainly not expensive but small things add up quickly and Sofirn needs to make a profit.
Though that was based on LCSC and glancing over some Alibaba listings I guess they could find something closer to 0.3-0.4$.
If an IPX7/8 port is not possible then hiding the charging port in the threads is the next best option in my opinion.
Since personally I find flaps to be fiddly, they will wear over time (no longer water resistant) or better yet just fall off.
Sure, with the in-threads-option an o-ring will wear as well but I’d say they’re lower maintenance? Threads will have grease so there’s probably going to be enough grease on the o-ring itself to reduce the wear rate. And if damaged then it’s relatively trivial to change.
Current interest, BLF+TLF combined: 312 flashlights.
@sbslider: yes, a 18350 tube will be a cheap, easy and very nice addition, not neccesarily for around the house duty, but this light makes a pretty good EDC too with that. Added that to the wishlist.
Maybe 21350’s will be coming too.
There’s apparently a vaper on the market that can take 21350, but haven’t seen batteries yet.
(Yes, i know the title says 18650)
The Waterproof USB Type-C Connectors look great for this purpose, but how long will it take for some Chinese manufacturer to start turning out the cheap copies needed? And can they copy it correctly without making something that leaks eventually? It can’t just be “good enough to sell” it has to be “good enough to serve” and stay that way for years.
They dont have to reinvent the wheel. They can just buy some cheap local off the shelves part. Even the lowest end cheap Huawei phones Ive tried have waterproof USB. Infact they work better than my Samsung Galaxy Note 8, which had water infiltrate and couldnt get back out causing tinny echos in the speakers.
