Charger Rydbatt 16 NiMH JBC038-11
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 4 days ago
DSC_1152
DSC_1154
DSC_1153
This is a 16 slot NiMH charger for AA and AAA cells.
DSC_1125
DSC_1126
DSC_1127
DSC_1128
I got the charger in a cardboard box with some Chinese writings on.
DSC_1150
The pack included the charger and a power supply.
DSC_1155
The charger has a 12V input for the power supply, it is rated for 2A.
DSC_1157
There is two displays, each covering 8 slots and a button to trigger a discharge cycle.
The button must be held down to trigger the discharge cycle.
DSC_1639
The battery symbols are animated while charging or discharging and a text shows what function is active.
DSC_1914
Discharge mode.
DSC_1151
DSC_1641
DSC_1156
DSC_1160 DSC_1161
DSC_1162
The charger has the typically two level slots used for AA and AAA batteries.
supportedBatteryTypes
supportedBatterySizes
DSC_1164
Measurements charger
  • When not powered it will discharge with less than 0.15mA.
  • Power consumption when idle is 0.3 Watt, the power supply alone is 0.06 watt
  • Charge will restart charging after power loss, or battery insertion.
  • The charger has four charge channels, that is switched between the 16 slots.
Charge
Rydbatt%20%28eneloop%29%20%231
The charger uses a -dv/dt (or 0dv/dt) termination and supplements with trickle charge. The termination is a bit slow, it takes more than a hour to detect a full battery. Average charge current is a bit below 0.5A
Rydbatt%20%28eneloop%29%20%232
Rydbatt%20%28eneloop%29%20%233
Rydbatt%20%28eneloop%29%20%234
Rydbatt%20%28eneloop%29%20%235
Rydbatt%20%28eneloop%29%20%236
Rydbatt%20%28eneloop%29%20%237
Rydbatt%20%28eneloop%29%20%238
Rydbatt%20%28eneloop%29%20%239
Rydbatt%20%28eneloop%29%20%2310
Rydbatt%20%28eneloop%29%20%2311
Rydbatt%20%28eneloop%29%20%2312
Rydbatt%20%28eneloop%29%20%2313
Rydbatt%20%28eneloop%29%20%2314
Rydbatt%20%28eneloop%29%20%2315
Rydbatt%20%28eneloop%29%20%2316
It looks like the charger uses a charge circuit for each 8 battery, the charge current for the two sections are different.
Rydbatt%20%28eneloopPro%29%20%231
On this fairly old cell the charging stops a bit early.
Rydbatt%20%28fujitsu%29%20%231
This cell looks fine.
Rydbatt%20%28leise25%29%20%231
The leise cell is also handled fine.
Rydbatt%20%28eneloopAAA%29%20%231
With AAA batteries the current is reduced to about 0.25A.
Rydbatt%20full%20%28eneloop%29%20%231
Usually the charger is very slow to detect when a battery is full, with a full battery it is faster, but still needs more than a half hour.
Rydbatt%20%2816xeneloop%29
The 0.5A charge current is maintained with 16 batteries in the charger.
Rydbatt%2012V%20%2816xeneloop%29
The charger uses up to 1.5A from a 12V supply.
Temp7322
M1: 39.5°C, M2: 42.5°C, M3: 41.8°C, M4: 38.5°C, M5: 32.0°C, HS1: 45.8°C
Poweron
The charger is fast to start and uses a pulsing charge current.
ChargeCurrent
There is a 2A pulse every 8 second, the pulse is about 1.7 second long.
ChargeCurrent4
Checking voltage on the 3 first slots, as can be seen the charger switches between them and also the fourth slot.
The next four slots are synchronous with the first four slots. The last 8 slots is in another group.
TrickleCharge
The trickle charge is done with similar pulses, but the time between them is 10 times longer, i.e. a 2A pulse every 80 seconds and it is about 1.7 second long, this means a average trickle current of about 40mA
Discharge
Rydbatt%20discharge%20%28eneloop%29%20%231
The discharge cycle will discharge all batteries and then charge them again.
With a single cell the discharge current is in the 0.6 to 0.7A range and the charger stops at about 1V.
Rydbatt%20discharge%20%2816xeneloop%29
With many cells the discharge current is reduce to about 0.2A and the charger may discharge down to 0.7V or lower.
It will first switch to charging When all batteries are empty.
Temp7327
M1: 39.6°C, M2: 36.6°C, M3: 36.7°C, M4: 34.7°C, M5: 37.2°C, HS1: 47.7°C
The heat is distributed over the full length of the charger and it is acceptable.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This charger is fairly good at charging many AA batteries, I could have wished for faster termination and lower (or none) trickle charge. The cycle/discharge function is not that good, because it over discharges some batteries when doing multiple batteries at a time.
Notes
The charger was supplied by Banggood for review
Read more about how I test USB power supplies/charger
MRsDNF
MRsDNF's picture
Thanks for the review HKJ. Nice to see Banggood chip in.
