Some older members will remember the Mini-01 which was quite popular at the time and even more so with the BLF Mini-01 driver version that was available. I carried a 02 on my keys for a while and had a modded Mini-01 and gifted some.
Originally a head twisty 16340 light with three modes driver and built in USB charging I saw some potential to make this better.
TrustFire Mini 08 XP-L HD 3D - QLite 3A Moppydrv - 16340 - E-Tail Sw - Rechargeable - 950lm.Stainless steel body
Cree XP-L HD 3D emitter
Copper core Alu MCPCB
18mm Glass
Op reflector
Brass pill
GITD LED gasket
MTN 17mm QLite 3A 8x7135 driver
Moppydrv firmware
Electronic tail switch
Micro USB charging at 450mA
Length - 74mm
Width - 20mm
Weight - 69g (with 16340 cell)
Max -950lm, 60s stepdown to 50%.
30% - 300lm
Electronic tail switch, copper signal bar, copper signal contact disc in head, brass positive and sprung switch body contact.
Red & green charge indicators, 450mA charge current.
TrustFire Mini range Models 01-08: (The 06 was aluminium, no number 4)
TrustFire Mini 07 XP-G2 S42B - DD - 10180 - Rv Clicky Tail Sw - 190lmStainless steel body
Cree XP-G2 S42B emitter
Copper DTP MCPCB
10mm TIR optic
Brass pill
Carbon fibre body trims
Single mode DD (2ΊR)
Reverse clicky tail switch
Length - 43mm
Width - 14mm
Weight - 21g (with 10180 cell)
Max - 190lm OTF
TrustFire Mini 07 runtimes:
I made the Mini-07 into a 10180 tail clicky light by removing the USB charging unit and installing a 10mm Omten clicky switch.
The driver was three mode, high, low and strobe :FACEPALM: and I broke it trying to fix it so it is now just a single mode.
To make use of the tiny micro USB charger circuit I removed from the Mini 07 I made this stainless steel charger unit:
CRX Stainless Steel 10180, 10280, 10440 Tiny Pocket Charger - 105mA.Stainless steel
Red charge indicator
Micro USB
100mA charge current
Length - 39mm/ 55mm
Width - 12mm
Weight - 10g
