I’ve actually been using some foam that I’ve cut to shape to stuff in the input hole which I use for small lights but just didn’t photograph it.
I have used some white paper over the holes to reduce the light saturation and might double up on it a couple more times. Is this acceptable as a cheaper (!) alternative to an ND filter?
White paper is probably fine but it will age and it’s not very durable. If you take care to keep it in good condition and not adjust it then it should be OK.
As JasonWW was trying to explain: Try white paper or foil on the underside of your foam and re-test a small light. I’d bet your readings will change some due to the foam absorbing some of the light instead of “integrating” it back into the sphere.
Hi hcanning, how is your sphere performing, specifically at higher output levels? Reason I ask is that I am seeing inconsistency with mine between lower lumen levels and higher lumen levels as posted here. I see your sphere has a complete opening at the luxmeter rather than just being pressed up against the foam like mine is (see pics of mine posted here). I also am not using any diffusion material in mine, nor am I blocking the entrance hole with anything other than the light itself (and maybe part of my hand at times. I need to figure out what I’ve done wrong with my sphere and how to correct it for more trustworthy results.
One more set of 2x Convoy S2+, XM-L2 (low CRI, cool white) and SST20 (high CRI, neutral white) available from the latest batch. Price for the kit is still 67 € including international shipping.
I need to purchase a calibration kit please, as soon as you can manage. I am located in London.
I am interested in measuring all kind of lights, from 2000K 95+ CRI to 7500K 70 CRI. What calibration kit would you recommend for me? Do you think the CW low CRI + NW high CRI will work well?
I recently got back into flashlights and set up my tube the other day, it seems quite accurate but I’m thinking a calibration light would be a good idea.
So although it’s been 7 months here with no reply, I’d like to know this too!
