Nice price, no strobes.
Couldn't resist. If I don't like the smooth reflector, most P60 pills seem to have the same threads so I'll be able to find something that works better.
Couldn't resist either :-)
It says "3 mode" (H M L)
Exactly. Even better!
aaaaaarrrrrrrrrggggggggggggggggggggggggggggggggggggggggggggggggg what is waiting DX¿?¿??¿
XM-L P60 dropins available at MOST Hk based shops!!!!
¿will I have to avoid DX and purchase in others? I made several product requests..... some posts in the forums request.............. nothing
arrrgggggg
"ultrafire branded".. ummmm dont worry If I get one I will change the driver for the 2,8A kaido one
Good find! I asked Manafont how much this dropin can pull; will report back
Same here.
Em i the only one wanting the SMO reflector? :D
Hurray for manafont! This dropin is about perfect by specs!
Personally i wouldn't mind some more hotspot and with the addition of KD lenses this thing might extend the range a bit since it is quite limited.
Too bad I ordered two 8xAMC7135 Drivers and empty P60 drop-ins just today. I were planning to build a C2 light instead. I'll see if I can resist in a couple of days. :)
But a P60 reflector can never be more than 26.5mm in diameter. You'll never get monster throw out of a P60, you need wider and deeper reflectors for that. Given that, better beam quality would be nice.
But it will get tested at distance. There are some KD lenses/windows on the way.
At least you will have a good floody light, precisely the thing that I need..............
I also ordered one, to test along with the one bought from (ebay) hkequipment...
Lets see which one is better...
Welcome asot. Don't think I've said hello already.
I have the KD one as well and will be interested to compare the two.
Thanks.
Been reading you all last month, but didn't find a good chance to "jump" in...
Aloha and welcome to BLF asot!
Yup, I saw that one too.
It's just a matter of time before I pull the trigger
(Brighter IS better)
MMMMMMMMMMMMMMmmmmmmmmmmmmmmmmmmmmmmust resist the urge to ........................ buy !
Must resist , the DARK Side !
Welcome asot, enjoy your stay. :)
Resistance is futile.
I know it's from a different movie series but I just had to say it.;)
It was futile , I could not resist ... I held out for several hours then caved ...
