If you keep running into issues, post a picture of your electronics and we’ll see if anything can be visually diagnosed.
will sure do if i do not figure what is wrong tonight, i kinda can believe, that 6 xpg3 can pull enough current to trip a 18650 pcb, but 10+ amps draw with several different drivers is definitely not right.
It sounds like a short somewhere if it is drawing over 10 amps.
that is what i thought at first, but no, continuity test showed no short. i hope it is my dmm that is the issue, will test tonight, i already borrowed another dmm, and have spare batteries.
leds do work, i run them off an unprotected cell and they light up and stay lit. protected cell however trips the pcb. but that i can believe, 6 leds, that are less than 3v, powered directly by a healthy cell that is at about 4v can pull over 6A which is what pcb in the cell is approx. rated at. but 10A with several different drivers, and cells, idk, some cells i tried cannot physically put out 10a.
the problem was my DMM’s battery, i replaced it and no more OL. on a half drained cell, or more, i had 4,5, at 3.7v under load, it took about 30-40min to get to 3v. since a poster before mentioned about temp, i ran leds to see how hot it’ll get, well it did not, it was pretty warm but not too hot. granted the cell was not fully charged, but i have no doubts even with fresh cell, 10-15W will not heat up the heatsink to a dangerous numbers. 9A however will, and pretty fast. so with no 9A driver no need for thermal switch,
originally i was gonna install 2 drivers, 4,5 and 9A. when the heatsink would get too hot a thermal switch would shut off either both drivers, or just 9A driver. even if both drivers would be off, i would still have white light in rgbw group, but only about 3W. or if i only wire 9A driver to the thermal switch, i’d have 4,5A. but now i’m thinking to abandon that plan, and instead use a driver that maxes out at 3.5A. i have drivers made by Quadrupel. they are D10 drivers, fet+1 iirc, with anduril UI. the driver fits under a 16mm switch boot just right, only few mm thick, has many different modes. has built in switch, all i need to do, is design and print a housing for the switch boot and a driver, and install it where i originally wanted to install a DT switch, so i will have 1 DT switch, and 1 pushbutton. which also has leds to light up the boot.
here is a pic i took while testing, caught a moment when current and voltage matched, lol
Looking forward to see how it all comes together alpg88!
switch\driver housing is done, top DT switch will turn power to rgbw driver and d10 driver, push button controls d10 driver.
if everything goes smooth i may finish it this weekend.
Cool!
Nice contrasting colours alpg88.
Wow! That looks very nice. Very neat appearing.
beamshots
Looks great!!
Those are some nice printed parts.
This really shows the power of Additive Manufacturing like with 3d printers.
Congrats on finishing your build! It came out nice.
I thought that UV light does not pass through plastic lenses?
Very nice, unique design, I like it!
thanks. it depends on uv and on lenses, polycarbonate wont pass anything below 400-405nm, pmma around 380nm.
i have ledil triple tir made from pmma. and 400nm uv led,
Now that’s the kind of thing that’s useful to know, thanks.
Very good indeed, has been interesting watching it come along.
