My reasoning for the C8+ is that ‘throwier’ lights are more ‘lumen effecient.’ For example, the 150lm setting on my Armytek Predator Pro can still punch out a long ways; at 100yds its much brighter then my 780lm Quark.
So for a single mode, ~150lm light, I figured the C8 would end up punching above its lumens, especially if used outdoors (walking the dog, looking for the lost cat, dazzling tresspassers, etc.)
That said, I have been quote satisfied with the range of my Malkoff M61LL, which is a 100lm OTF light, and uses a reflector thats much smaller then the C8 / Closer to the S2. However, all the pics of the s2 seem to show a really floody beam, whereas the Malkoff has a decent spill + strong hotspot.
you cant go wrong with convoys
ive got 3 convoy c8s and a few more on te way
ive got 2 s2 on the way and a fw1a on the way
it adictive torch owning! but its fun
sand coloured c8+ that i took the gubbings out of the black c8+
running sst40 6500k 2000lm (factory specs) and standard firmware that is factory, programming is super easy and actually very good. this is my EDC ,tail cap says 4.8amps
clear c8 with xhp50.2 6500k with bistroHD firmware configured with 4 mode, .low-med-bit more then med-max (temp controlled) not sure the lumens but matt smith says the are about 3000 . tail cap test on high makes 9.65amps on my multimeter but i dont trust that so much
the convoys s2s that come are 1x sst40 5000k and one host that is a project , not sure the led or driver going in
the fw1a maybe my EDC when it comes and i ordered the xhp50.2 .not sure the tint but it has OP reflector
one thing missing from convoy c8s is usb charging. it would be super cool if someone made a tail tap that had some usb charging in , im sure there could be a engineer that could make one
imight even try salvage a zoomie i have and try make something
Absolutely; 5D maglite was 151lm - but only for 30 minutes, after which brightness decreased by 50%.
Beyond that, the 150lm setting on my Armytek Predator (C8 sized) is surprisingly effective. And the 150lm setting on my Armytek Barracuda (64mm head) is awesome with how far it throws, can easily light up a palm tree at beyond 100yds.
For a regular person / muggle, I think a 150lm C8 would seem incredibly bright and effective; when I checked my Aunt’s 3D maglite in her drawer she keeps for emergencies, the batteries had degraded to the point that it was putting out ~1lm….
For 3D and 2D Mags, I kinda like the LED replacements. They ain’t screamers, but they’ve got more consistent output vs hotwire bulbs, and even alkaleaks last longer.
Still gotta pretty much beat people over the head with said Mag to get it to sink in that alkaleaks don’t last forever, and “emergency” or not, dead cells in a light won’t be of any use.
A USB charging version based on 2x21700’/ 2x26650 would be really promising as a ‘civilian’ light. Even moreso if they designed it to also function as a power bank.
I feel like a 150 lumen C8+ is just not going to be enough light
I’d recommend a driver with 4* 7135 chips which you could remove one at a time to get what you want. It’s going to be disappointing to receive a light that’s too dim and you have to buy another driver.
I spent $100 on a Malkoff MD2 M61LL, specifically to have a single mode, 100lm light that could run 10hrs.
So by comparison, 150lm is 50% brighter, and at $25, the C8 350mah is 400% cheaper.
I’ve been around flashlights a pretty long time; I had a 65lm incan Stinger, back when that was considered ‘blindingly bright,’ and later Innova X5’s ~2003, back when that was the height of LED tech. That was pumping out ~31m (on High!)
As such, I remember that 150lm is actually really bright. And paired with a decent reflector, 150lm has plenty of effective range; my Armytek Predator on 150lm mode (44mm head) has no problem at 100yd.
That’s why real garbage C8 clones on Amazon would still appeal to some as “blindingly bright”.
Stick a cheap Angry Blue™ XP-E clone (not even a real one) behind a plastic reflector and belt out a whopping 70-80lm into a teenytiny hotspot, and it’ll be pitifully dim but still manage some decent throw. And they’ll get those 5-star “Wow! That’s BRIGHT!!” reviews on Amazon.
You could get Convoy’s ramping driver and set the 1st mode to whatever brightness you like. It always starts on the first mode. You can’t accidentally change modes either, to get to the 2nd level it’s a very quick double tap, 3rd level is a quick triple tap.
I see this was first suggested by forsh but was ignored. He said to configure to 50% which is probably why.
I have this driver in most of my C8’s and it’s awesome. You can then set the first level to anything you want from 2 lumens up to 1250.
Get Simon to install his ramping driver into the C8 with XPL HI, he’ll then suggest it’ll burn out the led but it’s perfectly okay.
I guess the question is, what is the advantage of some programing driver vs just a single 350mah mode, when the goal is a single, 100-150lm level for 10hrs?
Does the 10% setting (presumably ~125lm if 100% is 1250lm) run longer then then the 350mah single mode?
Thank you for testing that. So 350mah should be ~125lm. Were those ‘OTF’ lumens?
In terms of multi mode, I’m well aware of the advantages, and the vast majority of my lights are multi mode, and with a better UI to boot (the previously mentioned ‘head tight - head loose’ interface. As such, I have no interest or need in a tailcap switching multi mode C8.
The goal here is a single mode light with an goldilocks level of light to runtime (~100lm x 10hrs). Which is actually an extremely hard to find flashlight; at this point there are hundreds-possibly thousands - of multi mode flashlights on the market.
There are a handful of single mode flashlights - but they are almost exclusively Turbo Lumens X 1hr runtimes ala Surefire. Useful for blinding muggers, but little else.
As of right now, there’s only 1 Single mode light that offers ~100lm x 10hrs - the $100+ Malkoff MD2 w/ M61LL lamp.
To me, this is pretty crazy, because thats the flashlight best suited to 99% of the worlds regular human beings.
The Average Person:
-Doesn’t collect flashlights
-Is not up to date on multi mode user interfaces (and does not want to learn them)
-Views a flashlight as a tool / emergency device, similar to a hammer or fire extinguisher
-Will use a flashlight for either basic utility (inspecting a dark area, walking at night) or as a primary light source in a power outage
-Doesn’t regularly change / charge their flashlight batteries, or even think about their flashlight until its needed
All of which points to a single mode flashlight (fire extinguisher simple) that offers enough brightness for the majority of tasks, and can last for hours even at 25% battery life (because batteries are likely to be old.)
Yet this simple, practical requirement has been completely neglected.
Which leads to this C8+ project. To create a practical, optimized performance flashlight for regular people. Or at least in my case, for handing out to friends and family.
