I think it’s a wrong thread for what I want to write. But since you Mike asked for UI suggestions and there were quite a few already I decided to go here.
Some time ago I got an YLP Falcon. It got an unknown-to-me kind of switch that acted mostly like a clicky but it actually had a momentary action as well.
I don’t really know how is such switch called but it raised my interest in alternative switch kinds. And yesterday I found something similar to YLP but without clicks - a double action momentary switch.
It acts like a regular e-switch but has 3 states: closed, lightly pressed, strongly pressed.
I find it interesting because it should enable richer UI while cutting those daunting multi-clicks to something shorter. And it is much easier to implement with the existing hosts than multiple switches.
Possibilities?
Some quick examples:
weak push ramps down, strong ramps up
press weakly from off to start with the default mode, press strongly for turbo
from off, press lightly and hold to ramp from moon, press strongly and hold to ramp down from Turbo
Thoughts?
Are there any other interesting switch kinds available?
I have tested dual action switches. The issue with the ones I tested was that they where so sensitive to heat that after soldering they where no longer dual action. I tried a few different brands. At least one other user experienced the same (scroll to bottom): Looking for a dual action switch
I’ll take it up again if someone finds a model that isn’t so sensitive to heat. I’ve given up buying randomly for testing as all of mine failed.
Good to know. I checked a few datasheets to see whether manufacturers give any specific soldering advice. Of those checked only ALPS did and soldering conditions were the same for all tact switches. 260C for 3 seconds.
Though low temperature solder seems like a reasonable workaround.
A general update on giveaway drivers: I’ve reached the point where I think the firmware is fine for giveaway. Far from all the functionality is implemented but I don’t really expect most features to be useful for anyone other than myself anyway. The main functionality is working and most of the quirks have been addressed.
I’m heading for more work related trips next week, and if the world doesn’t freak out about the virus and shut down all borders while I’m gone, I’ll get them in the mail when I get back.
I don’t understand this part, I haven’t ordered from Mouser yet.
I used to assume that they send from some EU warehouse and so there are no import fees.
But if they don’t, some fees should apply. What does Fedex do to prevent that?
I can only vouch for ordering from Sweden, but this is how it works here:
In Sweden the postal service has implemented an import fee. This import fee is for the post office that has to do custom declarations in all imported goods from outside EU. This is an attempt to get some money pack from the millions of small $2 packages from China that where declared is gifts.
Fedex have their own customs clearance procedure, they don’t need the postal services to do it so they don’t have to pay this fee. If I send/receive something myself with Fedex I would have to pay some sort of fee, but as this is Mouser sending they obviously have some sort of deal with Fedex. DigiKey has the same with UPS.
For me, ordering as a private person on Mouser, VAT is added to my total on checkout so that is taken care of too. The only difference with DigiKey is that the VAT isn’t added on checkout, I get a separate bill from UPS that only contains VAT. No import fee from DigiKey either. I prefer Mouser though, it’s easier with VAT added on checkout.
The drivers are ready to be sent. The firmware isn’t fully finished, but I don’t think it ever will be. Most features “normal” users would want are available, and most settings can be customized by user. I think the main kinks and bugs are worked out. I think (hope) any left will be minor.
Anyhow, I have not been keeping up on any restrictions in terms of postage due to Corona virus situation. I’ll be contacting each giveaway winner by PM to ask if I can send the driver now or if it is preferred to wait.
I still haven’t been to the post office. I haven’t done anything of much lately besides working and climbing, I haven’t been very active here either. I keep saying I’m gonna get it done and keep doing nothing about it, sorry about that but they will be sent. Anyhow, I’ll be checking with postal and delivery services before sending anywhere. The US drivers will be sent by Fedex because otherwise they will take for ever. European destinations will be checked case by case but I am sending them with tracking. No costs to any receivers.
Well, they are very specific to the ATtiny3217 which, from what I know, no one else is using. I think only gchart and myself are using the newer series of MCUs and therefore have the kit to flash them. They also use 2 digipots (expensice) taking up a total of 5 mcu pins (I’m powering them from MCU pins too). I don’t think they are of much interest really, they are just too different from what most people here are interested in. The regulators I use a very easy to use, reading the datasheet should provide enough to make drivers based on them and adaptable to current designs out there. With that said I can make a simple schematic without MCU and send it to you, just PM me with the details of what part you are interested in.
