I’m at 13! But that’s because the majority of my coupons have been pretty small ($1-$2); cumulatively, I’ve spent relatively little.
I think I’ll be done soon too - just a few more orders and my cart will be clear.
Used your #175 link, Serlite. And $#@%€, cos I just can't get what the @#$% is going on with the autoclicker software thing. The previous time I changed the tap rate to a tiny bit less than 9 taps per second and it nearly maxed out the bar, but this time it was like getting stuck for some reason, and even if it reached like a half bar by the end the final score was €0.28. Had to yell. Maybe these bastards have implemented some code to prevent autoclicker software from working properly unless you reconfigure cadence ratio each time. It probably is best to tap by hand then. God knows…
