RC,
UPS into surge strip. Not supposed to, but it happens all the time.
Just get a $7 power strip at the hardware store to put in place of the surge strip.
Then plug the surge and UPS into that.
All the Best,
Jeff
I bought a small CyberPower UPS to be the battery backup for my Amazon Echo Show I use as my clock radio. The Echo only draws about 2-3 watts during its nighttime resting state, so the UPS will give me several hours of backup power during the night, unlike its endurance for powering a computer.
I think the product is a quality UPS. The reviews of them are generally good.
Came in on 5 pallets at 5200 pounds total. I run 3 of them and 4 single phase 16 kva units. They are amazing units, just wish they could deliver the 100kva units in lithium ion, but you have to go bigger for that.
I recently bought three smaller UPS to help deal with frequent power outages.
I did a bit of research and decided on the CyberPower ST625. It looks like it fits your general needs (625VA/360W) and price range ($54.95). This model seemed to be a sweet spot for price,performance and reliability.
What I liked - Direct cable interface with monitoring software, 2 usb charging ports, 8 receptacles well spaced, low flat form factor, easy to find battery replacement.
Mine have been runing for a few months, so far so good. Maybe this will work for you.
Normally, when you see “& Free Returns” this means you can return an item for no reason. If it doesn’t say “& Free Returns” you can still return it, but only if it’s defective.
But I do see the reviews mentioning that Amazon is refusing to accept returns on this particular item. That is shady.
One of the UPS I received had the power button slightly damaged from shipping. I online chatted with an Amazon rep and it was arranged to have a new one sent to me. For some reason they do not want to have this item shipped as a return.
Please don’t purchase this depending on my return circumstances, I can not guaranty it will be the same for you. If you contact the supplier you will get a better answer.
I am not recommending this UPS or Amazon just sharing my experience.
It’s the shipping on these things that kills you.
That’s also why some places don’t want a cheap one returned. The shipping costs more than their replacement cost.
Cyber Power is known for their poor packaging on their 1200kv and larger sizes.
I usually don’t see the Pure-Sine Cyber Power versions at the local stores.
For the smaller home versions, Best Buy, Staples, and Office Depot.
With Staples (and?) you can get the larger sizes shipped to the store.
If you don’t like it or it is a brick. No return shipping.
All the Best,
Jeff
the ones to look for are the old apc and best power units with STEEL cases.
plastic=trash.
they use cheap transformers and no heatsinks in the new plastic junk.
and to top it off they have a timer in the firmware.
near the end of runtime with a stock battery its ready to melt down.
old and steel are what you look for in a ups to mod.
even some of the good ones can use a bit of help.
like charging regulators that could use a heatink.
or a hole cut in the floor where the battery once was to install a fan tied into the logic so it runs in inverter mode.
i have a connext(apc) on this system where the annoying beeper is clipped and the led fan shows its running from battery.
its on an 8d gel.
about 250ah.
One of the main things you should look for is how easily replacable/gettable are the replacement batteries. In many of the units the batteries are actually generic sealed cells that you can purchase from 3rd parties if you don’t mind a little extra work (sometimes you have to take the originals apart a bit, pull spade lugs apart a bit if there’s 2 cells, etc), from companies like battery technologies international (something like that, BTI) and others, for 1/2 the cost of the actual APC brand.
We have several small (to me, 1000VA to 3000VA is “small”) at my work, and that’s what we do. Our 5000VA up to 15000VA-48000VA we have serviced.
We go through a lot of these at the office, generally have stuck with APC but have had Cyberpower and Belkin and one old Tripplite that was actually a hunk of junk. With APC and Cyber honestly I've not seen much difference in quality on the inside although the newer units are not made quite as well as previous generations were. With APC almost all of their small station units like this can use generic batteries (which are just fine!) so you aren't locked in to an overpriced battery from them. They do have a couple that you must buy theirs, however. In your OP that BE-XXX line has been good for us so far (a few years) but we had very random luck with the previous models. I like the outlet arrangement better on the one you first posted than I do the Cyberpower just because it looks like you're limited to just one transformer plug on backup unless others happen to have a sideways arrangement. So a second monitor, speakers, etc, may have to go on surge-only (not so good for an office...fine for most people).
Deep cycle batteries are indeed not recommended, and yes, heat is the reason. I could never get a straight answer about why exactly these shouldn't be plugged into a (decent) surge strip since the rated wattage of these small UPS units is the same or smaller than most surges are...may be a good reason though (actual surges and clamp time or something?). We have people plugging laser printers into both surges and UPS units all the time when we aren't looking...don't do that. :) Or worse, space heaters.
We got to delve into "line conditioning" while chasing a gremlin and that was a learning experience. Basically these units (and surge strips no matter what they say) don't do squat for that. To get any real smoothing and steadiness you're looking at least $800 for starters. Tripplite even sells some sort of "conditioner" unit that is legitimately no more than a surge strip...sad, they used to be a highly respected company but they've really cheaped out and turned to "common marketing."
