No longer a “Budget” light but just (finally after a few episodes) received my Thrunite Ti. Originally bought it because it is titanium (as far as I know). I absolutely disliked the UI with next mode memory. I sent it to Vinh at Skyllumens for a complete rebuild. It is now fully programmable 3000k 95 CRI. It is absolutely what I wanted. It has a very low mode (not sure how low), a very high mode and everything in between.
Bliss for now.
GTvn Mini with SST40
OP reflector??
Yep, Vinh said the smooth reflector has a noticeable ring and donut hole in the beam.
Ah.
Nice torch ” BOO5TED ”
That is a good looking quality OP reflector
Who Dat !
Got this Nightraid flashlight kit 2 yrs ago and never put it on here. It came with 3 led pills and drivers in each one, White, Red, Green.
2 mounts, 2 chargers, tail cap with wired switch, and case.
I got lucky with local fb group and scored lightly used Knipex crimping pliers and new in box automatic stripper for $25. No more stripping wire with knife!
Our family has another rattlesnake!
My sister plans to kill it.
I hope she can do so without any humans getting hurt.
I'll keep you all posted.
Okay, the rattler is dead.
My sister killed it with one strike of a shovel.
The snake was near my mom's bedroom window, so we took the screen out to get at the snake.
My sister basically had a three foot wall between her and the snake, so she played it pretty safe.
I don't plan on posting pics this time, but I am very glad the threat has been neutralized.
Aww, why? Just give him some crackers…
Never mind. He dead.
Hi ” vulpes ”
I worked with a Machinist a few years back who was from Bosnia. Good family man and very popular. He bought 2 old oyster boats and fixed them up and made a good living with that side job. :+1:
People around here like making and fixing things themselves, be it a car repair or building a home (just no wires, electricity is regarded as dangerous black magic here). This may be the case in most of the places, but I’m always surprised with internet threads where someone who changed oil in their car is praised by hundreds (you get the idea). Well either that or being afraid to do as much as tighten a loose screw. Your guy was obviously an engineer, but since we have virtualy no waters to sail, or fishing industry, he is a very good example of this mentality that I really like.
Received the Nitenumen TK35 CREE XM-L2, today. It is an 18650 cell light. Bought it on Amazon for $16.99. It has five brightness levels, strobe, and SOS.
It comes in a very nice box for this price point. It also comes with a 18650 3400 mAh Nitenumen branded cell, a micro USB charger cable, a lanyard, an extra charging port cover, and one extra o-ring. Oh, and a decent holster.
It’s a two button setup. A forward clicky on the tail end, and a mode button on the upper side of the host. The buttons feel good. The mode button partially lights up blue when the torch is on. To get to strobe, simply hold down the mode button for a second while the light is on.
The body is nicely anodized, and machined with no sharp edges or flaws. The diameter of the first three and a half inches of the body is what you would expect from an 18650 battery flashlight. Then it bulges up to about the diameter of a 26650 battery. Then it flares out more for a wide beam. The onboard charging port cover is not the easiest to open, because it is so small.
It will tail stand, but does wobble a bit due to the cutouts for the thumb to better access the clicky button. The head is crenelated, so you will know if the light is on when set down on the head. The lens is glass, but has a blotchy haze on the bottom side. I don’t like the look of it. Never seen anything like it on a flashlight.
Initial beam test in a dark room is ok. There is a medium hot spot, then it has ugly blotchy spill around that, then some ok looking flood from there.
I feel that the TK35 is longer than it needs to be. The blotchy haze on the under side of the lens is ugly. Overall, I’m not feeling it…I think I will return it.
I don’t know how Amazon does it, but I got my Sofirn C8G today after ordering yesterday. Originally it said it would be delivered on May 4. Please, please, please! I beg for more vendors to have more great deals on Amazon.
The C8G is PERFECT! I mean everything lines up together; the “hot” symbol. The “Sofrin C8G” branding. The mode switch on the body. And, the thumb gap on the tail-end. Perfectly.
It works like the C8F in that you use the forward clicky button on the tail cap, to turn it on/off. You can leave the clicky button in the on position, and turn off the torch by holding down the mode button for about a second and a half. Turn the torch back on by a quick click of the mode button. EDIT: This works on Group 1 setting. A quick click of the mode button in Group 2 turns it on/off.
A thing of beauty, really. Can’t wait for the night to come. I might go for an extended walk tonight.
Got this SK58 clone.
I thought it would be a compact light but it’s not, a light of this size should easily fit 16650.
I got a 3M headlight restore kit.
I finally got an 8pak of toilet paper!
Was running low on Scotts (which I’m saving), did get crappy ¼-roll CVS-brand 4pax for a while, ordered a box of Tork huge-roll industrial TP that should be coming in a week or so, but finally had marginally-better Marcal for a change.
Jesus smiled on me…
The difference between the batteries is quite big in diameter and length!
Can you check the measures on the battery tube?
If you need a measurement of the 16650 I can help on that :+1:
