I’m curious when they’re going to actually be back in stock. I preordered my black one on December 13th 2019 and they never reshipped it after the first failed shipping attempt on January 9th 2020. I asked them many times since then when it may be back in stock considering they sold mine to someone else. I finally got sick of it on April 2nd and asked them to cancel my order once I realized no other colors were in stock either. For some reason the website has said they are in stock but as far as I’ve been told (as of the 2nd) they aren’t.
Which Keeppower?
The unprotected 6000mah is okay for this light, but to really get max output you need less capacity and higher amperage. I high drain cell is preferred.
Okay, that is a pretty weak battery with a lot of voltage sag. It should work if its unprotected, but dont expect full power. If its protected you’ll probably get even less power. You might only see about 10A from it which is way less power than the light is capable of.
I should have ordered the gt90 on the first group buy but I didn’t, now it says sold out until feburary 12th. Not sure what that’s all about but definitely not ordering it like that. I don’t mind a little wait but I have limits.
Well that explains a lot. That post was way up in this thread but I never heard the update. Thanks for the response, I guess I’ll have to go with the gt90.
I’m guessing the notice on Neil’s site saying out of stock until Feburary 12th is referring to 2020, and never got updated after it came back in stock. I sent him a message asking. If it is available I’ll probably just order that one.
