I earlier asked if it’s the same “Biscotti” driver (as used in the Convoy C8+ with Biscotti firmware).
Based on this explanation, the SST40 “Biscotti” is not the same “Biscotti” but “something similar function”.
I’m curious then, would it also have the same 12- mode groups, enable/disable mode memory? Or maybe just “something similar” in concept?
Would be good if someone has already gotten the “SST40-Biscotti” driver and put it to the test.
(As of the moment, our country is in lockdown, so most overseas sellers have stopped shipping to our country for a full month now and may still not be able to do so in another 2 weeks…) [eg. Banggood says “No shipping method available” for ALL products now, whereas before, only “pure battery products” have “No shipping method available”]
So it’s a Biscotti clone, but not Biscotti. And given that information is being withheld, I can’t modify it and flash my own version like I’ve been able to with Biscotti (custom modes etc).
Thanks, no thanks.
(I’d strongly suggest using another name - even “Biscuit (Biscotti-clone)” or similar. Because it’s not the same firmware.)
This was my mistake. At first, I thought that the driver manufacturer used the biscotti code. Later, I realized that it was the code he wrote himself.
I havent given a name to this, so simply call it 12 groups sst40 driver
I did notice a difference with mine but wasn’t sure if it was just a quirk with my build (used it in a photo red triple). When set to the five mode group, there seems to be a large jump between modes 2 & 3. My other Biscotti drivers have very linear mode spacing. Not really a complaint, just an observation.
I have a quirk in a 20mm “SST40” driver that I recently bought from your AE store. Between modes 1 and 2 there is a bright “pre-flash”. Is this normal? Anybody else experiencing this? It’s installed in an S21a running a triple XPL_HD from an LG M50.
I asked this to Simon nearly two weeks ago via message in AliExpress. I told him that, according to datasheet, a B4-40E should be U CRI code or CRI90+, whereas the D2-1A (6500K) should be H CRI code or CRI80+. Simon replied “uh, sorry, the LED I sell is not high CRI LED”. Confusing, I know.
I second that.
Myself I’m not a fan of Convoy lights because they tend to be too bulky for my preferences - but nevertheless there is no brand I respect more than Convoy.
