And tell him to finally make some nice old style zoomie flashlight as addition to his reflector lights. He is long time into this business and he never offered zoomie light…
For those of us who played with them, aspherics can be a major (or minor) PITA. In the past, BLFers offered aspheric lenses for the HD2010, and P60 lights. I bought both, of course, and did get them assembled but both were a PITA, and somewhat disappointing in results - not as throwy as we thought.
Dunno for sure why they are looked down upon, could be the poor quality of parts available for decent prices, or the complexity to get something working well and reliably. For sliders, PITA with the water resistance vs. the air pressure problems, the slide or twist mechanics - just a bunch of nasty issues.
Both Simon and Hank are into quality/reliability, so zoomies might not be a good option for them.
A build with his ‘5A’ linear bistro Biscotti driver delviering 4.62A and WF1 in an M2 yielded 80Klux. I think there’s more left on the table if there an AR/ultraclear lens and a bit more current. This is a SUPER setup IMO.
BTW, does anyone have access to the Boost HL (4040 1mm WF) or just ONE sample they’re willing to part with? L4P had a batch that sold out and I can’t find them available anywhere. Really wanting to push 100Kcd (turn-on) out of the M2. Not going to get it with the 3030 for sure…
Hmmm… Simon and Hank should not be afraid of their own OEM zoomie…, and regarding quality/reliability reflector lights should not be only option.
Imho in a future (if we will live to see) I would like to place a bet that zoomie lights will prevail… That is already happening with IR spectrum illuminator lights and new VCSEL laser modules which gives ultra high performance greater than any Osram and similar LED IR emitters and of course suitable host for them are only zoomie lights. So for example small 20 mm VCSEL zoomie is equivalent to 69mm Osram 4715AS zoomie. Runing driven at 0,7A vs 2,2A of Osram led. They are running cooler, longer runtime so only 1x18650 cell is more than enough + ultra light host. So it is just a matter of time until laser VCSEL technology will appear in visible spectrum… VCSEL are not that expensive either…
There are waterproof zoomies on a market so it should not be problem to make them waterproof especially if they will use acrylic lenses instead of glass ones. Obviously only Brinyte (and maybe just few manufacturers) figured that /acrylic plastic is more consistent, more resilient (shockproof + lighter) and better for mass production than glass.
Lets say twist zoomie: double o ring at the tail, double oring at lens section, and double oring on throat section… More than waterproof
My favourite approach to waterproofing is to add a secondary lens, could be a flat one that completely seals the light engine. Effectively a waterproof mule with added zooming aspheric. That’s simple and reliable. And doesn’t add friction.
I don’t think the firmware changes the current. I measured another driver running an SST20 at 4.28A. I could have had a measurement/zeroing error. Also, please excuse my misnaming of the FW. I meant Biscotti.
As for reliability, I think 4A/mm2 is pushing the limits. I’m obviously chasing some numbers here which is admittedly not practical. Just having fun with it. For a duty/EDC light, I’d run much more conservative drive levels.
Nice work. About 170kcd is what I saw from a C8 reflector. Didn’t put time into tuning it but it looked pretty much maxed out.
As for hosts larger than the L21A, you have the Convoy L6 + SMO reflector and the Noctigon K1 which will both yield around 600kcd at the same drive current. $$ start going up fast past ~60mm.
This zoomie has been in my AE cart and tempting me for months now. Nobody has mentioned or reviewed it. The HT line-up use acrylic lens, which really saves weight, cost, and improves performance on these large diameters. 66mm lens.
