Maybe is emisar d1 driver somwhere?
Big Thanks to ” Cereal_killer”:http://budgetlightforum.com/user/8679 !
Helped me with 29mm and 30mm contact boards.
Original quote from here:
Thank you Rufusbduck for this thread. I’ve been looking for 10mm drivers and it let me found notably more than I thought was available.
Pretty old thread, but used to be quite active and was the central main thread for our BLF drivers. Lots of famous names here...
Yep. Couldn’t agree more Tom E.
Interesting thread. Does anyone know where I can find boards for lighted side switches on Oshpark?
Perfect, thank you Chatika vas Paus. Those are the ones I have been looking for.
Been looking this over but can't see pin #2 connected to a pad for the switch - did you run out of space for it?
I know there's not much room on a 15 mm, to say the least.
DEL has a good write up on his 17 mm FET+1 here. He writes these are the mandatory parts:
- C1 10 uF
- D1 diode
- R3 100K ohm to eliminate unintentional flashing during mode changes
- R5 4.7 ohm to eliminate unintentional Vcc boosting during PWM
C2 and the R4 47K ohm resistors can be eliminated
Right, no space for pad , just connect straight to pin. Why not?
For 15mm, we make compromises
Might make it a pain to re-flash later
Sure, I've done it before.
I tried to (quick) read the entire post to find FW3A switch board or contact board but couldn’t find any.
Is it still a rare part?
Nice! I'm attempting to order from PCBWay - $5 + $8 e-packet shipping for qty 5, total $13. Decent price, no rush.
Looks like PCBWay has to do an approval on the order first. Thinking they will take PP. They also offer a ton of options - hoping the defaults are good for us.
Take 10pcs - same price ! ;))
Yea, I see that now - thought it didn't work before, but I was tweaking settings.
Unfortunately after the review, they raised the price from $5 to $15. Dunno - I'm re-submitting with qty 10, maybe I made a mistake before.
Ok, this time with qty 10, the price stayed the same . Looks like they give you choice of colors for the solder mask and silkscreen, but won't take the chance of changing anything now...
Transaction went thru! Also added a $5 coupon, figure it was for first time order, so total cost with e-packet shipping was $9, including a $1 PP fee they added.
Not Bad!
Took a while, but received the PCBWay order today! It's 11 boards, ordered 10. Had to think what the boards were for, til I found this thread
D10-D25 headlamp...Of course!
