Yep, as Phlogiston mentioned, the LT1 was designed with off-grid users in mind, and able to reduce the amp-draw charging rate to 0.75 amps for those with older lower-amp chargers and power supplies. One example is in many 2010 ~ 2017 RV’s, boats, ATVs have USB charger ports that can only supply 1-amp outputs. Another example is when i tested some smaller portable Solar panel chargers & power banks. i could connect one LT1 to many of them and they would charge, but if i connect two, the voltage would fall so low the lanterns would not charge at all. But when i reduced the charge rate in the LT1 lanterns to the 0.75 amp setting, then i could charge two at the same time from a tiny 10-watt solar charger in one day under good sun light after running them for 5-hours each night at 60 ~ 70% brightness.
right on. you are very thorough on your design methods. something i really respect, and appreciate.
this light is going to touch a lot of lives in a much needed way sir. well done.
on top of the standard functions, the ‘nice to haves’ such as candle mode, and sunset are welcome indeed.
thanks Toykeeper!
If you want the same discount as the group buy — Sofirn is making this possible on their web site … Selling the BLF LT1 for 49.99. As the web site states — This is for a very limited time … So If you want one — Here’s where to order:
ordered mine last sunday the 12th from amazon, it shipped monday (china time)
hoping it will be the usual week in customs, flown, week in customs then to my door.
one question… what the hell is this thing? lol
an extra button not shown to scale?
The BLF LT1 is safe to charge with my Ipad’s 2.4 amp, 12W power adapter right? I also have a couple of Anker Powerport PD2 wall chargers, will they be also fine to use with my blf lantern?
I ordered on 3/23 with special note in the order comments requesting the latest firmware. Light arrived in good condition on 4/17.
It does have the 5.0 driver but firmware is 2019/11/29. If latest firmware is deal breaker for you you might want to wait till the 4th batch.
C to C is not a deal breaker for me but I hope to test in in the next day or two.
I do not have the programming key for the exposed pads. If the wires are long enough I will try to re-program with the chip clip but i will not de-solder anything to do it.
This was a huge boon to me I used the spare button on a C8F with a mtn lighted switch it was exactly what the doctor ordered to make my adaptation perfect.
I haven’t kept super close track but I think 11/29 might be the latest. That’s what I have in my lantern. The only noticeable changes are SOS, and I think improved button press stability.
There have been two since 11/29. I dont know what the changes are but I suspect one of them enables C to C charging. The wires were long enough and I flipped over my driver my driver to flash 2020-03-18.
Took all of 5 minutes but it was a little off putting when Sofirn comes in here and states you only have to ask for the latest and when you ask you still dont get it.
But its more than that I have not had Sofirn get a single order right all year.
I ordered a SP10s w/batt and charger, did not get the batt and charger.
I ordered Q8 Anduril I received the older style Q8 with the flats on the body and Narsil UI.
Do they even bother to do more than glance at the orders?
I do appreciate the great lights at great prices, that’s why I keep giving them my money but for gods sake will it cost them money to get it right?
