I’m wondering if anyone knows, does the D25S fit nicely in Skilhunt HB3 headband? I’ve seen pictures that show the SP40 fitting ‘perfectly’ inside the Skilhunt band, but does anyone know if the D25S fits the same?
According to the measurements, both the SP40 and D25S have identical (25mm) diameter, but from the pictures the middle of the D25S extends a bit so I’m worried about the fit putting strain on the HB3 reciever.
Edit: Nvm, I just found a comment on reddit that says the D25S doesn’t fit in the HB3
PET-G hinges very well verses PLA, both dont like hi impact though. nylon prices and peculiarities means probly better of with a couple of castration bands and print in anything a flat board to mount the O rings.
insert…if your new in to printing, thicker it is the less flexable, the PET-G gets used for rc airplane wing hinging…its thin but does it, at about 2mm it starts not being a hinge/flaxable and more of a stiff component that flexs when you didnt want it to.
