Sofirn SP70 Driver and side switch PCB
14 posts / 0 new
YogibearAl
Last seen: 4 weeks 1 day ago
Just wondering if anyone knows the size of the Sofirn SP70 Driver and side switch PCB. Wondering if they can be purchased separate. I mostly like it for the simple UI, and ramping mode. Thanks.
zeremefico
zeremefico's picture
Last seen: 6 min 3 sec ago
Driver diameter?
Might be the same with Convoy L6
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
YogibearAl
Yeah from what I’ve read probably the same, but no idea on the side switch. Not sure if they sell the set. Only found Q8 driver and switches for sale.
Scallywag
Scallywag's picture
Last seen: 1 day 25 min ago
YogibearAl
Yeah I looked there as well. No SP70 parts.
Scallywag
Scallywag's picture
Right; I’d say message Barry here on the forums and ask to have it listed. Keep in mind with Coronavirus around, responses may be delayed.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 day 6 min ago
KB1428 “Live Life WOT
YogibearAl
Yes I just pinged them yesterday. Surprising how fast they put it up! They are very responsive to our community.
beam0
beam0's picture
Last seen: 8 hours 56 min ago
I also need to know the diameter of the SP70 driver please
Here’s a new link, the older ones here are dead:
https://sofirnlight.com/driver-of-sp70-p0050.html
RD
Last seen: 1 month 1 week ago
Sorry for my bad English.
YogibearAl
Got my SP70 Driver,
Main driver 30.03mm without the 2 bumps (shave or grind off if not needed) – Double spring.
The switch is a hexagonal shape – narrow parallel edges measure 11.72mm with the angled tips measuring apprx 12.42mm
- 1 common ground
- 1 main switch wire on/off
- 1 green LED wire for temporary lighting battery status above certain voltage.
- 1 red LED wire for temporary lighting battery status when below certain voltage.
The green/red led is a single dual color LED one on each side.
Switch has 2 tiny resistors for the red/green LED.
beam0
beam0's picture
Great, thanks for the measurements and info!
Also would the components on the board clear a 28mm driver opening? (looks like it should from the photo)
beam0
beam0's picture
Anyone happen to know specs of the input voltage for the SP70 driver?
Wondering if it can use 3S (12.6 volts)?
beam0
beam0's picture
Thanks again YogibearAl for the detailed switch info, it was very useful!
It’s a perfect fit, my switch opening measures 12.43 and my old switch board is11.76 at widest, 4 wires to the switch (lighted)
