LEPs are laser excited phosphors.
Instead of a blue LED there is a blue laser diode.
The light produced by the phosphor is regular white light like any LED, it is not laser light.
Also collimated flasshlights don’t case eye damge like a laser can.
Even though it is near collimated, the cross sectional area is hundreds of times larger than a laser and won’t cause eye damage.
I mean you’re completely right, the question is whether the law will consider something that uses a mirrored laser to create light from a phosphor (and then has multiple lenses to focus that light) anything except a laser itself. Especially with the beam it produces, and whether or not someone could blind pilots with it… it certainly will look like you could to most people. I think the smart thing to do either way would be to not use it near an airport if your areas has laws against lasers in a certain proximity. I’m not even sure the laws everywhere will distinguish between an actual LASER and any light emitting device… just in case someone thought it would be funny to point their 1940s searchlight at a 737 lol.
Do we have close-range intensity numbers to support that? They are hundreds of times brighter than a 5 or 10mW laser.
Look up NOHD, that’s the distance where you can get (termporarily) blinded because your blink reflex isn’t fast enough.
For example a 2W laser with 272Mcd (from wickedlasers) is at like 126m.
Since the beam of a laser is so thin and has such a small divergence, it’s safe to assume the whole beam can enter your pupil, which is 17000cd at 126m.
Not only is a flashlight like a maxabeam (with 12Mcd) far less powerful in the first place, it also has a beam diameter of 5.5” at the head, with 1 degree of divergence, which at 126m would be over 2m diameter.
This is over 3 million square millimeters of cross sectional area.
If your pupil has an area of 3mm^2 then that means that only 1 millionth of the beam intensity is actually entering your eye.
At 126m the maxabeam is 756 candela, so only 0.000756cd is entering your eye.
So that’s like 20 million times less intense than the laser.
If you had a giant magnifying glass and you focused the whole beam from a flashlight into your pupil, then yeah you can get eye damage.
But since the beams of flashlights (even the best ones like a maxabeam) have very large divergence, it’s impossible to cause ocular damage, not enough light can eneter the eye.
Also the maxabeam is far more powerful than any LEP that exists, and has less beam divergence, so it’s a pretty extreme example for comparison.
You’re confusing lux (illumination per unit of area) with candela (peak intensity) Candela can be a single point within the total beam and the surface area that you’re covering with beam of “X” intensity doesn’t matter. If 17,000cd at 126m is rated an eye hazard, then 17,000 (or the significantly higher numbers from LEPs and other lights) at point blank is a hazard too.
If you could theoretically block out 90% of the beam (from a cross-section perspective like you said) of an LEP the cd would be exactly the same (assuming consistent intensity throughout the whole beam, which probably isn’t true to be fair).
Just a correction to my measurement of the C8+ using the Osram W1. I forgot I was using the wrong centering gasket as the 3030’s hadn’t arrived at the time, range increased from 850m to 975m
Width, wideness is the biggest factor for good throw. The depth will keep the spill area narrower. I couldn't see any measurements on that light, but looks like about a C8 in width. I got a coupe lights with reflectors about the same dims, and no more, or much different than shallow reflectors. The old HD2010 was a good example of a wide reflector, shallow reflector but had good throw.
This led in a looong reflector will not likely do anything different than other leds: producing more or less the same throw as a shorter reflector of the same front surface area.
Took a nice bunch of lux measurements with my smartphone in front of the above white flats from Kaidomain (≈11 second averages with a luxmeter application, 0.1A current steps).
I finished quickly with the CSLNM1.TG (1mm²), I measured output at a few figures up to 5.1A (where I obtained its maximum) so I decided it was good to be driven at ≈4.7A with the Convoy ∅17mm SST-40 5A driver.
The 2mm² CSLPM1.TG was another story, noted down quite a bit of figures and while I could have gone a bit further (got a maximum at 7.4A, but given the previous and subsequent values I'd say that maximum was probably a tiny bit over the top already), I already had what I needed. No way 8 - 10 A, definitively. Between 6.0 and 6.7 A, I'd say.
Barkuti, nice work! I bookmarked the post. We get spoiled by Hank's QC/QA on his Noctigons. KD just isn't there (yet I hope), but actually Hank has always been keeping achieving quality/reliability as best he can. I find stuff like this though in stock flashlights as well, Lumintop recently, but other brands as well. I always try to post the details of the hidden defects to make everyone aware.
Hank used to contact me occasionally if I'd be interested in a batch of reduced price rejected MCPCB's. I'd bout always buy them - the defects were such minor things they made no difference, but sure enough, they'd be marked with an X as quality rejected.
Barkuti. Thanks for the testing and info. Always appreciated!
Are planning on rerunning the 2mm test after fixing the MCPCB issues? Very curious how much peak current may have changed. It seems like the KD batch has a really low current Imax limit.
May you also remove the LED from the star and photograph the solder coverage as well? It seems there is something off… 5.1A/mm on the NM and 3.7 on the PM seems like too big of a gap IMO
It doesn’t appear to, and yes, that would be an obvious bottleneck combined with the poor flatness. I guess I assumed it was epoxy since there weren’t any mechanical fasteners… 5.1A on the NM1 also suggested the setup was at least reasonable sufficient.
Both MCPCBs were already fixed with 2000 grit sandpaper, no need to re-run.
Now, yesterday I had a @#$% day. Emitters were thermal glued to the heatsink (with Tian Mu grey). Got really mad at me trying to forcefully remove the MCPCBs from the heatsink (alcohol, turpentine, pliers, …) slightly damaging the CSLNM1 board, and literally ruining the CSLPM1 with a blow. Ended up carefully sliding a razor blade underside, this worked pretty well. Lesson learned. :((
The performance of the CSLNM1 was definitively within margin (I didn't try anything higher than 5.1A). Concerning the CSLPM1, can't really say. djozz could only measure a maximum of 7.5A in his early test, beware so. Some more formal output tests are required, imho.
I'll order some CSLPM1 from led4power for my build. I will keep the driving current definitively under 7A anyway, there's really not much to gain near the limit.
