Looks great! SBT90.2 would be an absolute overkill for this size of light, but it becomes a true pocket rocket.
for the sane people a XPL HI will be perfect ;)
I like both ideas. A single SBT90.2 and a triple.
I've passed on the FW21 Pro because of the tail switch, so very much interested in this side switch version! It's somewhat along the lines of the Amutorch X9, but the X9 has to be modded of course to get Anduril in it, and change out the LED's to preference.
Yes, the sideswitch version is very interesting ! But no SBT90 LED, thats to much for this small torch and it would be only a “Blitzlicht”…
A single XHP50B NW or XHP35 Hi could be a great combination with a nice beamprofile…
Interested in the new design.
I love it!!
Suggestion: Add full knurling to the body tube. Unlike with the tailcap switch FW3A’s cigar grip, the most natural position to hold a side-switch light is a handshake grip with your palm around the body tube and thumb on the button.
- With the cigar grip, you don’t necessarily need knurling on the body tube since the goal is for the fingers to slip up to the raised tailcap with the thumb on the tailswitch.
- However with a handshake grip, the light will feel a lot more secure in the hand with knurling on the body tube.
Lack of knurling on the body tube was one of the major criticisms with the Emisar D4 that was fixed in the D4V2. It would be best not to make that mistake with this new light.
keep them ideas comming! ;)
I would really like a side switch FW21 Pro version in silver to gray, xpl hi or similar. I also like the smoothness of standard version through. Bought 3 Convoy S2+ butt button lights, that is enough
Well the XHP35.2 domed ones are same 12V, same rated Vf, same rated amps, so nothing new or better (https://budgetlightforum.com/t/-/52143). If the HI version was 3V and could take very high amps, then it becomes interesting. Something like a SBT90.2 but in a reasonable size package at a reasonable cost.
News on the XHP35.2 HI version in the EOL doc from CREE: https://www.cree.com/led-components/media/documents/CREE-PCN-1058.pdf. Haven't found or seen a spec yet on it though, but if it's like the HD, nothing new, might even be worse.
I too like the idea of a side switch for a light of this size. Keep us posted with the led ideas please!
Were they thinking of a triple XHP50.2 initially?
Is the SB90.2 made for more of a thrower?
I’d love to know more about the idea behind each design. I’m not up on all the new emitters.
As the happy owner of the XHP50.2 in 18650 I see the SB90.2 in 21700 as the logical step up. In fact a big WHY NOT? A question to you Martin or any of our experts. How many lumens do you expert from this set-up?
Skylumen squeezes 3 SBT90.2 intonthe FW21 PRO
looking forward to see the numbers he can get
I would buy either type of fw21 pro if it came with high CRI, neutral white emitters. I don’t need 10,000 lumens, I’d just hope the extra mass will permit a higher sustainable level.
Did anyone actually used a FW21 Pro?
10k lumen in a palm size light off a single cell seems like a stretch or a recipe for a massive extinction event. Something’s gota go wrong! Is there any review?
I already have a compact triple XHP50.2 3V light, modded Amutorch X9, smaller than this light. 10K? No big deal - mine hit 11K.
maybe matt smith willd o a review soon, he usually gets a sample for most lumintop lights…
Matt will make a review soon
i have a very early Sample which is not as well performing as the production units...
Are the fw21pro much bigger then a fw3 series Martin
Could you make a side by side picture maybe
