I need to double check with my clamp meter, but yes… I should be getting 3 full amps. Not set up for direct drive, though a FET+1 driver would be pretty easy to design for this. FETs are ok, but I don’t need this to be an absolute hot rod.
Don’t forget, for FET you can buy a GT Micro driver from Lumintop aliexpress that drops right in. I couldn’t get Anduril working when I tried to re-flash it though but the stock GT Micro firmware works fine.
It sits on top of a fairly large copper pour which should hopefully spread the heat out and into the body. And with it being limited to 3 amps, hopefully the FET won’t be needing to dissipate more than 2.4 watts or so (4.2V battery, ~3.4 vF LED… so 0.8V dropped across the FET at 3 amps = 2.4 watts… if I have my math right). That’s a far cry from the 15+ amps that a lot of people are trying to put through a FET.
I just put this thing together at 2 AM. I still need to put it through it’s paces (thermal testing, etc).
Rotary with stepless ramping
High CRI sw45k
Sapphire lens
eSwitch
multi fuel: Cr123/16340/AA/14500
Tritium locators
Firefly of less than 0.005 (as low as an RRT-01)
max of 200 High CRI Lumens
Thanks - that is an excellent comparison! I knew sometimes UV was used in such photos to show trits, but (and especially before owning any trits) didn’t really know how great the effect was, or how to tell in pictures.
Do you have a link for the GT Micro driver? I looked on aliexpress but couldn’t find them. It would be nice to get my 2 UT01 lights working properly without having to unscrew the tailcap all of the time.
I found the tir in my spare parts bin, so I’m not exactly sure where I sourced it (it could’ve been kaidomain or fasttech). I had to use an o-ring to fill out the space as the tir was slightly loose without it. I also removed the led ring in the install and there is no problem unscrewing and screwing the bezel on and off, not twisting the MCPCB and wires. The beam is narrower. The outer circle of the beam is less green but there a yolk in the center. Overall, it looks better to me but I’m a sucker for tirs.
