Emisar D3AA is available now
KR1 was made complement the KR4, it is 18650.
Head diameter 35mm, length, 110mm.
W1 110Kcd, W2 100Kcd. XP-L HI 45Kcd
Due to this yearā€™s complicated situation this has been slowed down a lot.
Awesome! Thanks, Hank! Any timeframe on the Nichia E21A? And will a range of temps be offered for that emitter?
The E21A LED should be available by June.
That looks really great, Hank.
18650? :person_facepalming:
SBT90.2 mule on KR1? :smiling_imp:
Yeah, 3*SBT90.2 :smiley:
Now we need a K1 mini (D1s replacement).
@Hank Wang
Title of your new light says QUAD.
NOCTIGON KR1 QUAD TAIL E-SWITCH 18650 POCKET THROWER
The 18350 variant is very cute.
Why do you want to use SBT90.2 as a mule? Itā€™s amazing as a thrower but if you want a mule, rather it be the much cheaper and more efficient XHP50.2
The KR1 is like a tailswitch D1, not D1S.
Put a boost driver and XHP35 HI in that and Iā€™d be quite tempted.
Arg now to decide between the W1 or W2 the specs difference isnt as big as with the K1ā€¦.
Exactly my thoughts. I donā€™t think a 10% increase in cd from 100k to 110k would be that noticeable. Whereas an almost 50% increase in lumens from 900 to 1300 would be.
It is not noticeable that 10Kcd extra.
But hey people think F1WA is a thrower with 35Kcd.
Hank any chance you will be able to source the W1.1 and W2.1. I think with the W2.1 in the KR1, it might even out throw the W1
I think a 35Kcd light can definitely be a thrower if the beam profile is narrow and has minimal spill. Its all about ratios.
100Kcd to 110Kcd will be barely noticeable, but 10Kcd to 20Kcd will be noticeable.
W2 sounds interesting, but Iā€™ll wait for the first reviews with photos of the beam. Also there might be more LED choices then.
Does the KR1 use the FET for direct drive or is it limited to 5 A?
I think the price is a bit high as it has just one emitter and no aux LEDs. Not sure how much the reflector adds to the BOM, but just $5 difference to the KR4 feels a bit overpriced. Especially compared to the D1.
Keep in mind some LED options for the quads add $10 or more to the price, even more for the 8x mule versions I believe.
I believe Emisar/Noctigon sit firmly at the ā€œpremiumā€ end of budget flashlights. Their build quality and fit and finish is superb. Their prices are fair, IMHO.
