Drop.com $20 off - Lumintop Copper/Brass Tool for $10 - Discount not available as of 12/10/19
> Because I’d had activation mistakes that drained the battery down, the slight twist of the head “saves” the light for me.
glad you found a solution that works for you…
curious how long the eSwitch stays charged, when you unscrew the head?
almost sounds like you would enjoy an AAA Cu Maratac body more…
I would consider receiving a CU Tool body in trade, if anyone wants one of my AAA Cu Maratac bodies,
AAA Cu Maratac body works with the 219c head from the drop Tool:
eSwitch stays charged. Because if you press the button while the head is loosened, you’ll find the light goes on when you tighten the head. So the on/off mode change happens due to the switch still having power. :sunglasses:
both is best
silver colored Tools are nla
Neal has some colored ones
Anyone got the xpg3 version? Is it that bad?
yes, and yes
you already asked before, here:
my words and pictures online cannot really show you what you need to see
I think you should buy both, and decide for yourself.
Love my N219 Tool Ti and my N219 Drop Cooper (although I’m not a fan of copper patina, sure does look sharp new!).
you can make copper lose its patina, even inbetween the knurling, by soaking the light in ketchup… but, that produces a dull pink color, not shiny. Basically the vinegar in the ketchup, and the acid from the tomatoes, etches the copper.
when I want to polish my copper, I use a jewelers rouge cloth, or a yellow sunshine cloth. It only gets the high spots though…
Should have read this earlier :slight_smile:
I was thinking of getting another one. And if for normal emergency purpose, will the cree gives more usable light or is negligible. The Cree will suck tint wise. And I don’t like cold white.
But will it be more helpful in dark basement or dark building car parking space.
Well just received the nichia. I think the middle mode is plenty bright. No need to go the xpg3 route.
And middle mode is really important I think. So in future I’ll be getting light with 3 mode also. Maybe another drop, this time a brass one.
2700k sst-20
Yay! congratulations :slight_smile:
very nice! :+1:
Received a CuTool w 219c… This time there was no glue, the pill unscrewed easily.
Installed 3000k 219b 9080, shown next to 219b 4500k 9080
Copper Kills Coronavirus, pic is a link to more info
look, a new Mechanical Clicky (that can handle LiIon) Ti Tool:
and fwiw
Neal has some of the TiTools with the eSwitch on sale
the preon clips are now on sale for $9 for two
shipping will be about that much,
ask the seller, he is very helpful and I believe he will mail to you.
PM me if you want me to remail to you
Here is my latest clip install, it is deeper carry, and I am very happy with the hatclip configuration. (bezel up for handsfree clipped to a hat brim)
I added an extra O ring between the lens and reflector to install the clip above the brass pill.
IF I had a thin metal washer, I could install below the brass pill.
I tried making a ring from steel wire… it was too thick and the light did not work… The extra washer under the lens is working well…
ps, the CuTool is no longer on sale, but that did not stop me from ordering another one.
Nice clip. Thanks for the tip!
Happy to share info here. Glad you stopped by.
Ordered the 2 clips. But I can’t seem to find a Tool AAA Ti Nichia anywhere. But the clips are just right, and I’ll find a use for them. One can go right on my Tool AAA Cu Nichia.
atm the only one I know available, is blue }P
:person_facepalming:
I have bought the blue Ti Tool from Drop.
The color of this blue Ti Tool is not as (solid) blue as the edges of this post, for instance.
It is more like a blueish haze on the titanium surface. Nothing like the blue Sofirn.
I am (a bit) colorblind, and I like them both.
