I would like to see the sales statistics of this one. Probably only for most hardcore enthusiasts
✌ FREEME - ASTROLUX MF05 SBT90.2 7000lm 3000m+ Thrower Searchlight - $390 (restocked) + Free Charger
Interested!
There is a fan inside?
Where can I read the specs?
No fan. Sorry. That will be the MF06.
Interested
Who’s the manufacturer, Mateminco?
It is about time.
looks like it needs external cooling same fan like acebeam ?
External fan will cool down light quicker.
Light needs active cooling, this the type of light I would run for over an hour at full tilt out in the field.
It doen’t need active cooling for one SBT90.2. Even the GT can handle it.
The GT can handle it, but not your hand. It gets hot.
Matt Smith tested it and he could still hold it from the end of the handle after 15 mins (I think). This was with the light facing down. In actual use it wouldn’t get as hot and the MF05 has even more cooling fins/area. It also will have a carry handle so i don’t think heat will be an issue. I have never owned the GT myself but judging by the size of this MF05, it doesn’t seem like 100W should be an issue.
Edit: Just realised it has an extrenal fan so it should be no problem. Hopefully they can make a similar sized light to compete with the MS18.
Interested
The GT70 and MF04S suffers from heat soak on turbo after about 2 mins.
Preorder will start in July 2020.
I want one
Sure.
I want one
May I ask what is the price range?
Astrolux® MF04S XHP70.2 RP is $245.95.
