Interested.
ASTROLUX MFO2S SBT90.2 SECURE!!! HAHA
Sounds interesting I would buy one.
Interested!
Interested
Interested, depending on final price.
Thanks!
Interested in 2, but depending on final price, good Host because of a good compromise of weight and volume... thanks !
Waiting for specs/price info.
I’m in very interested thanks
Will the 8x18650 extension tube work?
Interested!
Interested
Why? Is that for more power or for longer duration?
Hella interested!
Interested
Interested
cell setup is 2S1P or 2S2P
the extension tube should work as well
My modded MF02 with 4P battery setup and fet DD driver making 5830 lumens and 660 kcd with SBT90.2 and 4x Samsung 30Q batteries.
So I think the Kcd is right but the current and lumens rating too high. I tried everything to lower resistance. Bypassed springs in carrier. Double wire bypass on driver center spring. One of them is a 18AWG and go through the PCB and soldered directly on LED+ wires. Maybe with doubble led wires and VTC5A cells I can gain a bit but not much.
But I think this will be much better from factory than the FT03S.
Interested, depending on firmware
Can we trust Astrolux to make a decent buck driver? For a claimed… let’s see, 4700lm continuous, that’s gonna be around 16A continuous to the LED. ~56 watts continuous output.
Will it have the same dreadful parasitic drain my original MF02 has? Never saw four entire 18650s drain so fast in a light that was “off”…
