Do any of the ones you’ve acquired have the writing on the can under the wrap (especially the one with batch 136)?
I have a couple of 30Qs bought from ebay.au (not techaroundyou though) that seem mostly OK but I have had doubts. They have 3-prong top caps that look identical other Samsung flat tops, and the writing on the wrap shows no variation in typography of the kind that others have reported. They are marked batch 136 like other 30Qs. When new they tested slightly lower capacity than other 30Qs (maybe 7-8% down) but their internal resistance was very similar to other flat-top 30Qs. They seem to deliver good current in use, but that is a subjective assessment and not tested. My main concern has been the absence of writing on the can inside the wrap, like on other Samsungs.
Capacity and resistance testing done on an Opus BT-C3100. My capacity measurements are usually about 3% higher than HKJ’s at the same current draw (done at 1000mA). I have found that resistance measurement on the Opus is much more consistent and closer to those reported by HKJ if I maintain firm pressure on the slide against the back of the cell.
So my question is: is the absence of writing on the cans inside the wrap significant?
The same question applies to the two other cells depicted by Barkuti. Neither of them has the two lines printed across the cell with “0” as the second character on the first line.
On the other hand, I have a bunch of Samsung 20Q cells from Aldi power tools. They have marking across the cell in two lines C0HV / N6D81. That is a zero for the second character on the first line. As 20Qs they have only 70% of the capacity expected of a 30Q.
Good catch and good to know, along with another one I received it in some old early AE order :facepalm: long ago but didn't actually internal resistance tested them; I just presumed what they were with the limited information I had.
I have a 30Q from NKON which I'll shoot and rewrap for a better picture.
Just for the record, Liionwholesale claims that some recent batches of the 30Q might have weird can markings due to temporary production facility changes. I have a few marked making me think they were 29E’s as well but they have similar IR and capacity to my known legit 30Qs with good can markings.
Sooooo I just realized my two latest batches from Lucky’s Electronics Store on AliExpress sent me 30Qs with the top line of code “L30Q” . This has been my trusted supplier for the last 4 years and is listed on BLF as a trusted source.
I’m just charging a couple up to do a discharge test on my CBA.
I had 100pcs with an added button top arrive genuine but looks like my flat top are fakes.
Genuine always test at 3.40v and these read 3.44v.
EDIT: Well, they’re genuine. Tested at 15A and got 2968mAh and it almost perfectly matches the curve of Mooch’s test back in 2018
Just starting fairly recently, I’ve started to record measurements of batteries (from shipped condition: voltage & IR as tested with YR1030 resistance tester, and weight; I haven’t started doing measuring dimensions though).
So far the genuine 30Qs I get arrive usually from around 3.36v-3.45v. and there seem to be 2 sets of IR readings, I think both are genuine.
1 set of 30Qs (“141”) have YR1030 IR reading of around 11.8-12.0mOhms, while the others (“136” and “138”) usually around 12.6-12.8mOhms.
I have the same resistance tester as you and two cells with L30Q read 12.06 & 12.11. It’s very interesting that these are genuine when Mooch said if it hasn’t got “0” as the 2nd digit it’s fake
One online shop in my country has a good deal of 30Q (around $4.5 per piece). But the close-up picture shows a faint code R30Q/JCKA6 (I think). It is neither “0” at the 2nd position nor “L30Q”. In addition, some VTC6 pics in this shop show LiitoKala sticker on the cell (I heard a lot of fakes in Liito store).
I’m not sure whether to buy from this shop or not. I also don’t have tools for testing, so buying and testing it is not possible now.
Additional reference, this is the picture of markings on pink wrap.
$4.50 a pc sounds pretty cheap though but if he’s buying in massive bulk then they’d get a better discount than me. My cost price is $4.40 usd excl shipping.
Goatlvl, the top or positive pole of cells is a distinctive trait. Battery brands carefully choose the geometry and shape of the top pole for their cells. Its like an emblem, unique. Different brands never (!) use the same top / positive pole. This is the shape of the Samsung one:
