Yes, that is most unfortunate and why I couldn’t bring myself to pay the usual $35 for one, but being as I have a specific albeit seldom use for a small 3000k high cri light, I can deal with the $18 and change it ended up costing.
I did see it claimed somewhere that 14250 batteries can be used with a spacer. Do you know if this is true?
Got my Vokka today. The finish feels good with no sharp edges or visible blemishes. The battery tube is about the diameter and length of a 26650 and has a lot of extra space inside for an 18650 to rattle around, but the springs seem strong enough to prevent it from happening despite a few vigorous attempts. Although there is a tail clicky, it does not completely turn off the light as half presses still turn it on no matter how many clicks you try and no tailcap lockout. USB charging seems to work, nothing special and hopefully it doesn’t compromise water resistance. Brightness seems better than average for a $5 flashlight today. With both LEDs on, the hotspot is not as bright as my Convoy C8, but it is much larger and probably more useful for general use. The color temperature seems to be pleasant, not too cool or warm, I’d guess in the 4k to 5k range. Overall it seems to be a good deal at this price, as long as the parasitic draw doesn’t prematurely kill the battery due to not having a true off or lockout.
Well heck, sorry to hear that. If you unscrew the section behind the clip it will expose the switch and you can try the switch without the rubber cover or silver button potentially interfering.
Possibly use some fine tweezers to make sure the driver is in firmly and the switch as well. Can’t be much more than that?
Or do what non-flashoholic people do: send it back and have a new one sent!
Oh yeh, the other one’s nice. Makes a better vampyre than a 1×AAA light. Tossed in some dead cells, still lit up with rather decent brightness whereas my Wuben/Ultratac 1×AAA lights wouldn’t even turn on.
Got mine today and I agree with Kuoh.
It is pretty darn nice. The matte black ano is really nice, nice threads too.
Each led can light individually. Very bright with a 18650 and not as bright with AAA’s.
On the Vodka.
Here’s what I read, fast and dirty;
First mode, both candles lit = 5.54 amp
Second mode, bigger reflector = 1.10 amp
Third mode, small reflector = 1.85 amp
Do no show any draw in between clicks but you must make contact with battery twice to change modes, bizarre. My meteris cheap, not a Fluke so there may be residual bleed that I can’t read but it has to be low if there.
All readings with low ohm purple IMR battery, has a big diamond with and E stenciled inside, whatever that brand is. Voltage before readings 4.15
Will check with Samsung 30Q as soon as it is topped off but these purples are usually a hair hotter than the 30Q
With Panasonic 3500 measured just over 5.04 on First mode.
Update; Just tried sample #2 and it wasn’t as high amp draw, off like 1 amp on high. Got battery tube loose (this one had brown glue) and cleaned edge of contact on paper and re assembled and got more power, went to 5.12 so still not as good as #1 but battery hasn’t been recharged either so will see when retested.
Another trick if you don’t care about water, flip over the conical ring, makes a good cigar grip.
Very interesting light for $5
I got my Vokka today. I’m ready to just toss it in the trash. It’s the worst light I’ve ever held, lol. The UI is garbage, the emitters suck. And it’s not even worth as a host since the body is way too huge for an 18650 but still doesn’t fit any other battery. Not worth it.
