Sofirn IF25A received today!
56 posts / 0 new
Zappaman
Zappaman's picture
Not a review but an observation after this first night with this light. AND notice they are on the way to a mailbox near you. Thumbs Up
Mine came today and I eagerly awaited the dark night (no moon) then finally got out to “see what I could see.” Wink
I went out an hour ago with the IF25A and my C8F (21700) host (I put together last March using 18g wire throughout and shaved XPLs which run about 5.5k after slicing).
This is the 4k version of the IF25A and so I didn’t expect a lot of throw compared to the C8F. I have to say I was pleasantly surprised as it kept up pretty good. The beam is nice and WIDE and very natural at 4K of course. I ran it on turbo for about a minute and felt the heat coming down the tube pretty quick though! Not super hot, but about as warm as can be comfortably held on a June night in Kansas.
I looked down a fence line (I use as a gauge of distance as it starts in my back yard and runs about 150 yards going away from me at a slight angle). I could see the wooden fence posts VERY clearly out to 150 yards with the C8F. Then swapping the Sofirn 21700 (4000mah) stock battery between lights, I was able to barely see the same fence post with the IF25A, but the “field of view” (of the “field” to the side of the fence that I “viewed”) was really nice and wide as mentioned.
Light came in a nicer color printed box with the acetate light holder inside and included: the 18650 tube, a NICE, long USB charge cord, spare o-rings, and a fitting lanyard (with the nicer THIN end loop). There is a smaller notch on the tail cap that this lanyard can JUST get through- and I LIKE it because it fits the form factor of the light.
This is a small light for a 21700 battery. Everything in this design seems to me to be about getting a 21700 light that can be used as an EDC light. No clip, but this light easily slipped into my gym shorts pocket and didn’t feel heavy for my short trip to the backyard just now. The trade-off in head mass compared to the C8F means it heats up fast driving the four LEDs at top output— BUT it does drive them! Out to 150 yards, the little IF25A keeps up with the C8F build pretty nicely all around.
If I were technical back packing (like I did in the 80s) where every ounce counted… this light would be the perfect pack light. And given the USB charging, small form factor, and 4k output and solid, wide throw past 100 yards… this light will be going in my hunting pack (next to my C8F rifle lights). With a 4800mah 21700 battery it should run for days as a hand carry in normal use. And the USB charging is really a luxury as a charge is a car (or solar) charger away while out in the wild for a week.
The heat factor might not make it the best muggle light though. I’ve ran some of my C8Fs hot a few times, and they certainly can get warm. But the IF25A got hot pretty quick running on turbo for less than a minute. While I always WANT the light run 100% full out when I run up to a turbo setting… it’s rare that I ask more than a medium brightness beam 95% of the time in normal use. With that, the IF25A gets the job done and packs some output and throw not usually found in smaller lights like this little beast.
The IF25A will make an excellent addition to the “Sofirn shelf” until September when it will see service through the winter at camp and whenever I’m on the road to about anywhere Beer
ZappaMan
Edited by: Zappaman on 06/09/2020 - 00:00
Funtastic
Funtastic's picture
Last seen: 2 days 6 hours ago
Thanks for your input.
I’m guessing you haven’t used a Fireflies E07 with 20 sec turbo before hitting 55°C. That thing is nuts but I don’t see the point myself when you can get much cheaper for the lumens it can actually handle.
It would be interesting to know the genuine lumens as the IF25 was rated at 2300 lm but only measured 1650 lm.
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
Zappaman
Zappaman's picture
No, haven’t played with a lot of lights as I just got addicted here these last few years Wink I also need to brush-up on my photo posting skills and do better with my postings as pics are worth (my) 1000 words I’m sure.
I would LOVE to buy a light from you sir… that would mean I was standing in New Zealand! I hunt (a lot) and dream of a place like NZ where you can hunt pretty much year round. Kansas is cool about the deer though as I am allowed up to 5 Whitetail tags (one buck, four doe) a year. I Ate venison back-strap for dinner last night in fact… never gets old. We also have good Turkey and wetland birds here too. But if I ever get rich enough to go anywhere in the world to hunt, I’ll be dropping by (for a year) for sure. Blushing
ZappaMan
samyy
Last seen: 1 week 2 days ago
Mine arrived today. Everything works except the memory settings. I cannot remove the “automatic memory” setting. I know the theory, its five clicks and so on. But its does not work. Any ideas?
d_t_a
Last seen: 41 min 32 sec ago
samyy wrote:
Mine arrived today. Everything works except the memory settings. I cannot remove the "automatic memory" setting. I know the theory, its five clicks and so on. But its does not work. Any ideas?
Also just received the IF25A a couple of days ago.
Tried to determine the Anduril version of this IF25A by using some "checkpoint" notes that I compiled using the Anduril changelog history..
Newer Anduril versions have the "version-check" function so it's easy to determine which Anduril version (compilation date) was used.
Older Anduril versions, need to check which "features" they have or don't have..
some notes I compiled:
Quote:
Anduril version (compile date based from TK's changelog):
2018-12-14: fancy aux-LED (button switch LED) blinking mode (like heartbeat breathing effect) on BLF Q8/SP36
2019-05-22: 2-level lockout (4-clicks); momentary strobe mode possible (go to strobe modes before going to momentary mode)
2019-06-02: manual memory option (5H) ; button-release time-out is a bit faster
2019-06-27: factory reset function (hold button while tightening the tailcap)
2019-09-24: version-check function (15C) ; safety ramp-down if button held too long
Based on checking out some "features" of the IF25A, I notice that:
 - the button-LED has the "heartbeat" effect (7-clicks to change the LED blinking state to "Blinking"), which implies the Anduril firmware version date has to be 2018-12-14 or later.
       (comment: if the "blinking" state is just plain "blinking" and not "heartbeat blinking effect", then it has an even earlier firmware version)
- when in Lockout mode: it does not have the 2-level brightness, nor the momentary strobe; which implies the firmware version date has to be earlier than 2019-05-22
So the firmware is likely between 2018-12-14 to 2019-05-22 (the same is actually true for the Astrolux EC01, and the Sofirn SP36 BLF Anduril).
The "automatic memory" toggle feature you're looking for is only present with firmware version 2019-06-02 and later..
jasontheguitarist
Last seen: 1 day 6 hours ago
Tried to determine the Anduril version of this IF25A by using some “checkpoint” notes that I compiled using the Anduril changelog history..
Newer Anduril versions have the “version-check” function so it’s easy to determine which Anduril version (compilation date) was used.
Older Anduril versions, need to check which “features” they have or don’t have..
Quote:
Anduril version (compile date based from TK’s changelog):
Based on checking out some “features” of the IF25A, I notice that:
 - the button-LED has the “heartbeat” effect (7-clicks to change the LED blinking state to “Blinking”), which implies the Anduril firmware version date has to be 2018-12-14 or later.
       (comment: if the “blinking” state is just plain “blinking” and not “heartbeat blinking effect”, then it has an even earlier firmware version)
The “automatic memory” toggle feature you’re looking for is only present with firmware version 2019-06-02 and later..
Fragmentation. There are so many updates so fast and apparently very little effort is made by the manufacturers to make sure they are using the newest version. Manual memory is my favorite addition to Anduril, I was interested in the IF25 when the Anduril version came out, but not if they are using an over year old version of the firmware. The IF25 isn’t listed on Toykeepers page, so it looks like updating it won’t be easy. Has anyone tried taking the driver out yet?
Blggg
Last seen: 8 months 1 week ago
D_t_a, can you please measure the current drawn of the IF25A? I’m kinda of suspecting that the current drawn of the 5-7 modes would be 1A, 2.9A and 6A like those of the test of D4V2.
d_t_a
Blggg wrote:
D_t_a, can you please measure the current drawn of the IF25A? I'm kinda of suspecting that the current drawn of the 5-7 modes would be 1A, 2.9A and 6A like those of the test of D4V2.
IF25A (4x SST20-4000k)
in ramping mode:
battery first inserted and turned on ~ 0.35A
ramp ceiling ~ 6A
Turbo ~13+ Amps (battery was 4.10v, so not "fully-charged", using Sofirn 4000mAh 21700)
in stepped ramp mode (7 levels):
7th level ( = ramp ceiling) ~ 6A
6th level ~ 3.3A
5th level ~ 1.4A
Blggg
Thank you very much, d_t_a. Just as what I suspected. If then, I think using a high drain 21700 would probably draw a couple of more Amps.
Zappaman
Zappaman's picture
Hum… it’s a powerhouse light for sure. As much as I like the output this thing can hit on turbo… the heat factor makes me second guess using a Molicel P42a I have in the fridge waiting for a light for a month now. But like most BLFer’s… I’ll probably do it just to SEE Big Smile
ZappaMan
Zappaman
Zappaman's picture
Well… just got back inside from a walk through the property with the Molicel P42a in my 4k IF25a and I am impressed!
BUT, muggle warning… this light gets HOT fast! I’d drop it out of turbo after about 30 seconds but even then (on the factory high setting) it stayed hot. I tried it for a full minute on turbo and it just got too hot to hold comfortably. It will make a great little hand warmer this WINTER when I am elk hunting in 5 degree weather. Wink
The throw was a tad bit more (to my eye) than when using the Sofirn 21700 4kmAh battery. The Molicel is a very high drain battery and although my custom (old 18650 version) C8F “outhrew” it— it wasn’t but much tonight.
The natural white of the 4k IF25a is really nice. I kept going between the C8F and IF25a shooting trees about 100 yards away and the main beam of the IF25a is literally TWICE the width of the C8F at that distance. And the rendition of the 4k LEDs in the IF25a is just “better” to my eye compared to my shaved XPL HDs in the C8F that are at about 5500k (after the “shave”).
This light is a real tight package and both the host and battery got hot fast as there just isn’t anywhere for the heat to go other than down the entire light. The C8F never got warm in testing (under a minute on most tests). Just confirms what I said before… IF you NEED high output for short amounts of time (typical use for me), the IF25a kicks butt! Evil BUT the price is instant heat for a super lightweight tool that can do it, but probably not without gloves in summer.
I see this little light being my go-to this winter where it will be more WAY more usable to me out in the field where the beam is WIDE, the ambient temps below freezing, and the throw is there for 99% of my needs.
Very cool (hot) light! Thumbs Up
ZappaMan
Blggg
Glad you like it. I really like it too. It does not use the latest version of Anduril firmware, which doesn’t bother me. Though it’d have been better if the latest version of firmware had been installed from the factory.
cothyhu77
Does the manual say anything about whether or not it supports 2xCR123 batteries? Might give some insight into what kind of driver the IF25A has.
Zappaman
Zappaman's picture
Funny you ask about the manual… this light didn’t come with one. Maybe they didn’t have it printed yet as this was one of the first to ship out just last last month.
I have to figure out Anduril. The light when clicked 6 times (I guessed right Big Smile ) changed over to ramping, but the ramping didn’t go up near as far as the step-up setting did on high (in the step mode out of the box). I am assuming I need to go set all that up.
Also when out last night, after heating up the light good… the ramping was almost immediately reducing the output after I hit the top of the ramp. And it wasn’t just trimming it down a bit, but dropping it WAY down to the first or second lowest setting. Anduril tweaking should fix this (I hope).
I find that because of its super wide beam, one has to run this light higher than most to get the same throw. For general hunting and any field use at night, most lights on medium output are fine. But I predict that when I get it set up, it’s going to need to ramp up to a more “high” setting— where it’s going to be running on the warm side for sure. Again, not a problem in most cases where I’ll be using the light.
ZappaMan
Funtastic
Funtastic's picture
Here’s my UI simple instruction to follow
6 clicks is Muggle Mode for simple mode for lending the light. Disables all the features and reduces output. Doesn’t work properly until you configure the temp sensor
Full Manual
Funtastic
Funtastic's picture
tirma
Last seen: 1 year 6 months ago
Thanks for the anduril UI manual. I was searching for it
d_t_a
Zappaman wrote:
Funny you ask about the manual... this light didn't come with one. Maybe they didn't have it printed yet as this was one of the first to ship out just last last month.
That's the plausible explanation, maybe first batch was missing the printed manual -- the Sofirn IF25A I got came with the correct IF25A manual describing Anduril firmware. (although it's probably not possible to write everything about Anduril in a manual).
Specs indicate 3800 lumens max (likely for the 6500k version) and 420 meters beam distance. 21700 battery recommended. (no mention of other battery types, although an 18650-to-21700 battery adapter is included in the package.
I tried comparing the beam pattern of the IF25A with an Emisar D4v2
(unfortunately the D4v2 I had is sort of customized - uses 4x SST20, 1 each of 3000/4000/5000/6500k, so an "average" of around 4700k)
Here is a comparison between the IF25A and the FM1, both use the same 4x SST20-4000k LEDs.
Sofirn IF25A (4x SST20-4000k) vs Meote FM1 (4x SST20-4000k)
(The FM1 is more floody, but even then, its brightness is quite dim)
Zappaman
Zappaman's picture
Thanks for the great info and beam shots guys!
So I just thought I was in ramping uh? My six clicks went to the weird ramping I described and I’m guessing the heat (I had already built up) was triggering a LOW temp setting that immediately reduced the output every time I ramped to the top (which was about 1/2 output compared to Turbo- for about a 1/2 second before reducing to low). Sounds like a perfect muggle ramping mode to me Wink
I ordered the 6500k version last month after getting this one. Thought I’d compare it to my C8F and see how close it really gets. Any luck and I’ll see it by August Silly
So I need to play with Funtastic’s chart here and figure out how to make this into a little super hand heater for this fall Beer
ZappaMan
StormRider
Last seen: 6 months 2 hours ago
Just got mine today after a month. Just want to mention I was able to charge the battery through the built-in USB C port at around 5V x 1.78A = 9 Watt. Also, out of the box, the temp calibration seems way off. My house is at 19C, but the temp calibration shows 31C. I had adjusted it down to 19C, hopefully that will keep the turbo a little longer.
BTW, here is how you do temp calibration in Anduril (text version of diagram above):
From Off
3 clicks to enter battery check
2 clicks to enter sunset mode
2 clicks to enter beacon mode
2 clicks to enter temp check
Flashing shows current temp
4 clicks to enter temp calibration
1 flash – follow by rapid flashing, while flashing, click N times where N=room temp in C, stop
2 flashes – follow by rapid flashing, while flashing, click N times (up to 35) to set max temp to 30+N, stop
Flashing shows original temp -> brief pause -> flashing shows new temp
1 click to turn off
Enjoy
Nismo
Nismo's picture
Last seen: 2 days 14 hours ago
I’m not sure if I follow correctly, the original IF25 had 2×2700K SST-20 and 2×6500K SST-20 with tint ramping, but does the IF25A have 4×4000K SST-20? Is the tint ramping function gone? I wish it had 2×2700K and 2×4000K instead with tint ramping.
Current lights:
Emisar D4V2 Dual ch. W1/LH351D 3500K, D4V2 Dual ch. E21A 2000K/4500K, D4V2 SST-20 4000K, D4V2 SST-20 5000K, D4V2 Ti SST-20 2700K, D4V2 Ti SST-20 4000K, D4V2 Ti XPL-Hi V3 1A, D4SV2 SST-20 3000K Noctigon KR1 OSRAM W2 | FireFlies PL47G2 SST-20 4000K, PL47G2 219B 4500K, E07 219B 4500K Lumintop FW1A SST-20 4000K, Tool AA 2.0 219C 4500K | Sofirn C01S SST-20 4000K, Sofirn SC01 SST-20 4000K, SP10S LH351D 5000K, IF25 SST-20 2700K + 6500K, BLF LT1 | ZebraLight SC700d XHP 70.2 5000K Hi-CRI Convoy C8+ SST-40 6500K Acebeam H30 XHP 70.2 5000K |
Zappaman
Zappaman's picture
Here is the link to the 4K version I have. Notice the 95 cri rated leds Thumbs Up
4K IF25a
ZappaMan
Zappaman
Zappaman's picture
After taking a few hours this afternoon I finally took my tutorials (thanks again Funtastic, your links were SUPER helpful). I reset the temp sensor which several users have mentioned is coming from the factory way off. I didn’t wait for mine to count it out though, I just reset it along with the thermal limit of 60 Celsius. I am wondering if I should have gone for 55, but we’ll see.
One thing that seemed to not work though was the upper limit for smooth ramping. I’m not 100% sure, but it seems that it was coming on at full turbo even though I chose the TWO (2) click limit. I also wonder if double clicking (for turbo) in smooth ramping ONLY goes up to the “set” limit. After I tried twice to set the limit a tad lower, it didn’t seem to work AND when I double clicked for turbo- it didn’t increase in brightness.
Because this light heats up so fast, I’m looking for the brightest setting it will run at (in smooth ramping) without getting ridiculously hot. I’m estimating that to be about 75-80% of it’s full turbo output after four times out with the light. The idea is to get smooth ramping set for a good every day use brightness being the top limit… BUT still be able to double click UP for turbo as needed.
I guess I have more work to do but one last thought is that although this color is REALLY nice (at 4k) when running it towards the top of it’s output capability, I have a harder time seeing even close in things with it at lower levels. I’ll have a 6.5k IF25a here in a month or so and really be able to compare the two. Several times I’ve though these four LEDs in a slightly larger head (a little more mass and deeper heat sinks) would be killer. The C8F would be too heavy for what I am imagining, but something in between would let you run these LEDs full out without the instant heat. But hey… maybe there are five lights out there already that fit the bill and it’s an afterthought on a HOT July night. Come winter, I’ll probably be GLAD it’s a little hand heater Silly
ZappaMan
Zappaman
Zappaman's picture
After further efforts, I realized the range of clicks is well interpolated. I had to click DOWN 40 clicks to get my ramp MAX to a level where it’s plenty hot still, but I can hold it in the bare hand. And YES… turbo is working now when I double click from ramping! Thumbs Up
I am VERY impressed by the light’s output on turbo. But it’s not a realistic option for more than about ONE MINUTE without a glove. Even where I have it running now at about 65-70% of turbo (estimated, and this is 40 clicks DOWN from the max ceiling setting), I hope it’s bright enough for outdoor woods out to 50 yards or so.
I would love MORE heatsinks and would give up a few ounces and a slightly longer (or wider) head to tame the heat just a tad bit. I’m still sure it will make a great winter light for hunting and such as it is, but in July in Kansas it’s really too hot to use much above 60% output due to the heat in the hand factor.
Anyway… Anduril and this IF25a ARE 100% working as expected, I just didn’t expect the heat which is manageable, but a factor if you aren’t comfortable with holding very warm things. Evil
ZappaMan
cothyhu77
I received my 4000K version today. The box didn’t contain a manual. Mine shipped May 19 from sofirnlight so it was probably one of the first batch or so. I set ramp floor to 10/150 and ramp ceiling to 100/150, and it still gets warm fast at ramp ceiling but not hot. After running the flashlight under cold water the temp sensor read 36C, so I recalibrated it to 25C. I don’t have any charged batteries that can really drive this thing on Turbo, so I haven’t tried running it really hot yet. The light won’t work with flat top laptop cells but works fine with Sofirn button top cells, due to the flat contact in the head.
The head has good machining but the body and tailcap have a lot of sharp edges. I found the body tube was impossible to remove from the head, anyone else’s light like that?
Tint at similar brightness is generally more yellow than my SC31B with 25deg TIR, which uses the same emitter. At higher brightness though, the tint approaches and surpasses the SC31B in rosiness. I’ve heard that the SST-20 gets less green at higher currents. As far as I know the SC31B uses PWM+FET so current stays pretty constant throughout its modes, so the IF25A uses something different. I decided to measure output at different voltages with my phone, so big margins of error:
3000mAh Sofirn cell @ 4.1V:
Some ramping level: 85 lux Turbo: 1056 lux
2200mAh Sofirn cell @ 3.4V:
Same ramping level: 90 lux Turbo: 315 lux
As my first Anduril light the UI takes some getting used to, but basic operation isn’t too complicated. I wish there was a way to access moon discretely from ramp floor, and I wish single click from turbo went into the previous state instead of off, but otherwise no complaints.
Zappaman
Zappaman's picture
Uhm… I have used flat-tops in mine fine. The front contact IS wide, but I thought it a design choice to make the light smaller (shorter). Both a Sofirn brand 4000mAh and Molicel 4200mAh flat tops fit and run fine in my IF25a.
Also, given this light runs so hot, and running it on turbo for long isn’t a proposition 99% of the time… I now wonder if a higher capacity battery might be a better fit. The Molicel is a VERY high drain battery and it does a great job, BUT the Sofirn 4000mAh 21700 “heats it up” just as fast Wink The difference in output on turbo probably isn’t 5% or so (if that… I want to “feel like” its brighter because the Molicel is a 35A drain battery!).
Anywho… the point is that without a glove, I’m not running this light high enough to benefit from a high drain battery like the Molicel. The Sofirn 4000mAh battery runs it just as good with the (possible) exception of a touch more output on turbo with the Molicel. But after that 30 second show… maybe a 5000mAh medium drain battery like the Samsung 50e (5000mAh capacity with 10A drain) 21700 would be a better fit as it wouldn’t heat up as fast and would increase run time by about 20% or so.
On that note; I HAVE a Sofirn 4800mAh 21700 I’ll probably try next. I doubt it would heat up any faster (passing it’s thermal/current rating) than the light itself. So that battery paired with the IF25a MIGHT just make a great “reciprocally regulating” pairing together Big Smile
ZappaMan
Zappaman
Zappaman's picture
Playing with this IF25a WAY too much lately Silly
I can’t get over how super cool Anduril is. I’ve been SLOWLY memorizing the IU the last three days and have now pulled out the LT1 and SF36 I didn’t get around to messing with much before.
After setting the temp sensor yesterday I tried an experiment. But first a few things to explain before the experiment:
I am running smooth ramping with a ceiling of 40 clicks down from the high of 150 possible levels. So the ramp starts at moon and goes to a set ceiling of 110/150 *** which is the same thing as saying 150 (max/turbo) LESS my 40 clicks = 110***. So this is often shown in a ratio of “110/150” which I didn’t figure out the first time I read it- had to get into Anduril first— THEN it all “clicked” for me. Looking at this ratio, one might say the light is on at 73% output… and to my eye that would be about right.
I ran the light at the top of the set smooth ramp set ceiling for 5 minutes today. I then immediately turned it off, and went into the thermal check function. The light “blinked” out 5 flashes, then 3 flashes = so it reported a temp of 53 Celsius about 10 seconds after I turned it off. THEN… I did NOTHING. I let the temp check keep running. After about 15 minutes the light got to room temp and was reporting 28 Celsius. THEN I took it and placed it on my AC vent for about 3 minutes until it read 21 Celsius. Finally, after another 15 minutes on my desk (where I am NOT getting any work done today) Wink it steadied to reporting 24 Celsius (75 degrees) WHICH IS EXACTLY the temperature in the room!
So, despite the factory temp sensor being off from the factory, MY IF25a (after calibration) is VERY accurately reporting the ambient temp in my house (within 1 degree accurate).
So in summary: I have a 60 Celsius thermal limit set. My light running at 73% of Turbo (at 110/150) hit 53 degrees after 5 minutes running (in the same room tested). And the final “resting” temperature is “dead balls on” accurate! Thumbs Up
ZappaMan
cothyhu77
So I finally got the 4000mAh battery charged, and tried running turbo for about 3 minutes. When I went to turn it off, the flashlight was far too hot to hold, and I just barely was able to click to temp check. It read 67C! I swear I set the temperature limit to 55C with 25 clicks in temp config, do you know why it’s getting this hot?
Zappaman
Zappaman's picture
Because it’s a little spitfire light Evil
Did you set the temperature sensor up yet? You can try resetting the thermal limit in that mode too while you are at it. Probably did, but a check box for sure.
Then in the ramping setup, I clicked down 40 clicks to finally get a bare hand hold temperature of 54 Celsius. I think I could have gone a BIT less on the upper limit attenuation (maybe 36 or 37 clicks) to settle into a high 50s Celsius ceiling. But 30 was still TOO HOT for me!
I am beginning the think this particular 4K model might end up being an indoor light except in winter when the heat will WORK when it’s 10 degrees out Shocked
I have a 6500k version on the way and given it’s summer now, that model may be better for outdoor use right now. It seems that outdoors a few times now… I can’t QUITE get the brightness out of this 4K IF25a that I am wanting- without it getting JUST a little too hot in the hand today.
ZappaMan
MAX-MX
MAX-MX's picture
Last seen: 11 hours 44 min ago
Hi guys, does anyone know which optics are installed in the Sofirn IF25A, and where can buy narrower optics for it ?
cothyhu77
I had set it to 55C. Since then I lowered it to 50C and it’s more manageable.
I don’t know, but there is a teardown of the IF25 here on fonarevka: http://forum.fonarevka.ru/showpost.php?p=1245148&postcount=13
Says the TIR is 23.4mm wide and 7.8mm tall.
Note that this is the IF25 not IF25A so electronics and leds will be different, but I think optics are the same.
