Well, you said it, there are differences in beam profile and shape and you did not choose the most reliable mothod of measuring. You can try measuring the voltage and current and calculate the output power like that. I am not surprise if that measurement method would show that type of difference even in flashlight with spot on power output.
My green alum MF01 mini doesn't focus well - the optics are not all the way down. The brass one I have focuses way better, and can tell the optics are fully down. If yours has the problem, your measurements may be effected.
Just wondering if you ever got around to this? Just curious. Also how would removing and stacking on the other 7135 affect the output when ramping? Wouldn’t it cause ramping to jump on the stacked 7135? And would the flash light go dark when it hits the the blank spaces that got the 7135 removed?
One of mine has a dead aux LED. I’ll have to get a magnifier and check this out. If It’s crushed, well, it’s blessedly tiny but at least I know what the problem is.
Is this a new light? You might want to verify its voltage is high enough. They are already just barely running so a slight tolerance on one led might cause it to not light up. If you bump up the power and it still doesnt come on it might be soldered crooked or actually broken.
Hi
I dropped my MFO1 mini, a few days later I switched it on and it will not turn on.
Checked the battery and found it was completely drained.
After recharging the battery it still did not work.
When I found the flashlight was getting warmer I left it for 15 minutes and measured the temperature of the flashlight and voltage of the battery.
The voltage had decreased and the temperature increased
Can anyone help?
I went to use my MF01 mini today after not using it for 3-4 months, and found that the battery (Keeppower 5500) was dead. I tried to charge it as usual but my charger refused, so I tested the battery’s voltage and found it was drained to 1.5 volts.
Did I make a mistake leaving the light sitting that long unused? I read that AUX leds could drain a battery to damaging levels while sitting idle, but the MF01 mini specs say that the AUX leds on the board shut off before they drain the battery too much, so it doesn’t seem like it would be because of that.
Thank you for your update Lexel. And that you sent Astrolux/Mateminco the design and talked them into putting it there. Its great news. I might buy a few more as gifts now.
Normally you should turn the tail cap to break the electrical flow if not using the light for a long time. You will need to throw that battery out. It’s now a fire hazard.
It’s weird it went down that low. The aux leds should shut off at 2.8v. The drivers lvp is only active when the light is turned on, not when off. When off it should be using only a tiny amount of power. Enough to last your years. Maybe your parasitic drain is much higher than it should be. You would need a digital multimeter and turn the aux leds off to test it. It’s also possible the aux led lvp is not shutting down properly. Youd need a battery charged to about 2.6v or 2.7v to test that.
Way too long for me to remember, but I can say that I only used it for a few minutes at a time whitewall hunting, so I don’t think it would have been drained all that much.
Has anyone got a picture of what’s below the driver PCB (as shown below), so we can see how the driver board is attached to the light body?
The image below was taken from post 6. In this post JasonWW states:
“Actually, the battery tube does not contact the driver so that heat is not being drawn away.”
If that’s the case, then it’s no surprise the board is overheating. It’s just a matter of time. I was about to state that in all the teardown pictues I’ve seen on this light, I don’t see any thermal compound, but if there’s no ledge for the driver board to sit on then … that explains why.
I hope I’m mistaken, otherwise this is a case of very poor design.
There’s not much point in having a copper head\body option if the driver board is practically floating on air. Please tell me this isn’t the case……
Every 7135 board I’ve seen in other lights is pressed\soldered against the flashlight body so the heat has somewhere to go.
It is normal for a driver board to be mounted like this. There are components on both sides so it cannot sit flush on a flat shelf. It should not be a problem because the driver board does not generate a lot of heat relatively speaking.
The problem with MF01 mini is that the 7135s are transferring heat directly to the temperature sensor on the other side. Anduril sees a rising temperature and because the algorithm is partially predictive, it immediately takes steps. That is my understanding anyway, I am open to correction.
You are correct in your statement that it is poor design and testing. A single test would have revealed this problem to Astrolux, and almost surely did. They shipped anyway because that it is the Chinese way. They will keep doing it as long as people keep buying their half-baked crap.
