Lumintop FW21 Pro (10,000 lumen) vs Nightwatch NSX3 (9,900 lumen)
I found the answer: not the FW21 PRO. Cooked the domes and phosphor off
I was tempted before, but no longer
Oh wow!!!
FYI 1st thing I did after turning the light on was configure the Thermal limit and calibrate the temp sensors. Set the limit to 40C. By default it’s set to 45 I think and it thought the ambient temp was sub 15C (room temp around 22C).
I could see how it could cook itself at default settings… Good thing I like messing with settings lol
Also, another thing I noticed is that the temp sensor doesn’t update the readings often enough for this light.
Toykeeper mentioned that it updates every 6-7 seconds, which is fine for running Turbo from a “cold” start. But if you turn it back to turbo after it steps down, it will stay at turbo for at least 6-7 seconds before it starts stepping down gradually again, rinse repeat and now you have a dead light…
This light needs a temp sensor that is more “realtime” that updates every second and more aggressively steps down depending on how much over the limit it is
I wonder where the BLF Q8 lands for sustained output (and then, modded with 50.2s, what it can sustain)? Or lights like Convoy L6/Sofirn SP70
I know for sure that my convoy L6 can stay on turbo indefinitely, it doesn’t get that warm….
For that reason I decide to order SST40 variant of Nightwatch with 5k lumens because want turbo for longer times and its have better heat dissipation design compared to FW21Pro.
I have a stock FW21 Pro. Does anyone know what the color temp is with the XHP50.2 emitters in this? 5000k? Or 6500k?
The color temp is ok for me, but my only quibble with the XHP50.2 is the green corona around the hotspot is a little irksome, though it isn’t terribly bothersome - generally only noticeable when white wall hunting. But I do appreciate minor improvements, when I can get them.
Is there another emitter option, to mod this light with, to get rid of the green corona, but still retain reasonably high, cool white, lumen levels? Would XP-L emitters work well in place of the XHP50.2 emitters?
I don’t care if I can’t hit 10,000 lumens on turbo. For the most part, I would use the light within the ramp range, only using turbo very briefly on occasion.
Probably 6500K is original FW21Pro emitters. 5000K version of XHP50.2 are difficult to find and manufactured only by special order. Good replacement for XHP50.2 is SST40.
why not XHP70.2 ? they exist in neutral and warm white tints…
I’ve read that the SST40 has a greenish tint shift at med to low levels?
Good question! Do these have a greenish corona around the central beam, as the XHP50.2 does?
If not, I’m sure I’d be thrilled with moving to XHP70.2 in neutral tint.
No idea, i dont own any light with that emitter sadly… but i just placed order for the FW21 from neals… need this light haha :smiley:
What is the best battery for this light (NightwatchNSX3) for Max output? Samsung 30t? 40t? Button top, flat top, both?
I have a sofirn 21700 40a
and an ijoy 20700 40a
I don’t know if they are enough to do the job. Thanks for the input!
Max output bar none: Samsung 30T
Best all around 21700: Molicel P42a and/or Samsung 40T
I have 2 molicells and 2 40Ts.
I’ll see if I can do a full charge output test
I don’t think the type of top matters unless you arent getting contact…
do you have a suggestion on where to buy in the states
Flat top.
Imrbatteries.com is where I bought mine.
Thank you!
Is there any harm is trying the ijoy or the sofirn? They are both rated at 40 max amps
Link to ijoy I have
I appreciate your help!
No harm, you might not even be able to “see” the difference.
40 amps is plenty - IF you can trust the rating.
I just didn’t know if there was any chance of harming the battery or light I’m still noob
This is incorrect. Those are fake rating and usually top out at 15 amps or so
