Lumintop FW21 Pro (10,000 lumen) vs Nightwatch NSX3 (9,900 lumen)
72 posts / 0 new
Sunnysunsun
Sunnysunsun's picture
Last seen: 5 days 11 min ago
ch1ir wrote:
Rockenrooster wrote:
Ok I just tested my fully charged 40T against one of my Molicell P42a in my FW21 Pro (turbo of course).
My homemade lux meter box results (highest @ turn on using):
P42a: ~16,600 lux
40T: ~13,800 lux
(Note that these results are relative to me only)
I am not able to detect a visual difference in regular usage (dark room or outside), but the difference is measurable with a meter.
I’ve decided to reserve my Molicells for my FW21 Pro and use the 40Ts when I get my E07.
Thanks man! I grabbed a 30t and a 42a, I reckon I’m covered. Now to wait and see who arrives first!
This is a great choice. I usually carry bring 1 or 2 extra 30Ts on me depending on how long I expect to be walking and do a battery change midway through.
Before my 30Ts arrived, I had been using VTC6s and they became unreasonably hot when I used turbo in my NS53. The 30Ts look brighter and make the light heat up faster but the cells themselves don’t get as hot.
mortuus
mortuus's picture
Last seen: 2 hours 41 min ago
raccoon city wrote:
mortuus wrote:
40T is the best battery if u want decent runtimes and plenty of amps to run this kind of lights.
In my research, I prefer the Molicel INR-21700-P42A, which is pretty similar to the 40T.
I haven’t bought any 21700 cells yet, however.
yes that cell works also, it depends what u can find in local stores or online, for absolute most power the molicell is hard to beat. but i prefer the 40t though.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
SKV89
Last seen: 30 min 40 sec ago
30T is actually the most powerful 21700, will measure brighter than the P42A but only down side is 3000mah. I use it for taking max measurements.
andreas0401
andreas0401's picture
Last seen: 1 hour 25 min ago
Rockenrooster
Last seen: 1 day 22 hours ago
andreas0401 wrote:
FYI resetting it back to Turbo is bad. You’ll end up like that guy on reddit that melted his LEDs.
Toykeeper mentioned that Andruil’s thermal management isn’t meant for tiny hotrods like the FW21pro.
It takes about 6-7 secs before it takes action from a temp reading, during which you can fry the LEDs.
Not to mention it gets hot enough to burn your hands…
ch1ir
Last seen: 2 hours 54 min ago
How about the NightwatchNSX3
Emisar D⁴, Astrolux C8, BLF A6, Sofirn sp36aV2, Reylight Mini Pineapple, BLF 348 KillZone, Lumintop IYP07, Emisar D18, Boruit D10, Manker e01, Ultrafire z1, Massdrop titanium AAA, Astrolux HL01, Armytek Wizard Pro Nichia, Tacklife LFL3A, Astrolux FT03, Zanflair T1
Rockenrooster
Probably less so since it physically has more thermal mass.
You probably could still fry it since I think it also uses Anduril and same or older firmware.
These small hotrods aren’t meant for sustained Turbo of any kind, thermal stepdown is for the flashlights protection, Toykeeper just programmed it to be “easily defeatable”
I really do like that Nightwatch though…
andreas0401
After the third turbo start, the FW21 Pro was so hot that I could hardly hold it in my hand.
Rockenrooster
Lol! I feel that!
When I was messing with the thermal settings and found that resetting it back to Turbo makes even the MOST aggressive settings moot, I almost dropped it because it was so stinkin HOT!
It making the body so hot let me know that they did a good job with thermal transfer at least….just needs more mass and better/more cooling fins…
Be careful out there
mortuus
mortuus's picture
yes please dont do that ever again
              つ ◕_◕ ༽つ
sovereignknight
sovereignknight's picture
mizou51 wrote:
What a strange race we are facing in 2019/2020….the more lumens possible in a lowest possible time ?
It started with imalent flashlights 3 years ago…
i would like to see a small light that can sustain 3000lm for 10min.
I’m not sure if it can hold that for 10 minutes but I’ve had my Zebralight SC700D hold 3000lm for 5 minutes, (at least I never noticed any step down) however it was quite toasty!
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x2 Sk68 modded 1 Nichia 319AT, 1 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, w/ Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x2 Lumintop Tool AA - x1  x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - x1 Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light - x1 Lumintop Zoom 1 - x2 Zebralight Sc700d - x2 Lumintop Tool AA 2.0 Ti - x1 Olight I3T EOS
