Test/review of Xtar 18650 3500mAh (Blue) 2020
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 19 hours 59 min ago
DSC_2964
Official specifications:
  • Nominal capacity 3500mAh
  • Nominal voltage: 3.6V
  • Size: ø18.4mm H68.8mm
  • Maximum continuous discharge current: 10A
  • Cell: Panasonic-Sanoy NCR18650GA
  • Protection: yes
Xtar%2018650%203500mAh%20(Blue)%202020-info
A protected Xtar 18650 High capacity cell.
DSC_2963
DSC_2965 DSC_2966
DSC_2967
DSC_2968
DSC_2969
Xtar%2018650%203500mAh%20(Blue)%202020-Capacity
The cells are just about perfectly matches, the protection kicks in around 10A.
Xtar%2018650%203500mAh%20(Blue)%202020-Temp-5.0
Xtar%2018650%203500mAh%20(Blue)%202020-Temp-7.0
Xtar%2018650%203500mAh%20(Blue)%202020-Temp-10.0
Xtar%2018650%203500mAh%20(Blue)%202020-CapacityTimeHours
Xtar%2018650%203500mAh%20(Blue)%202020-Energy
Xtar%2018650%203500mAh%20(Blue)%202020-PowerLoadTime
Xtar%2018650%203500mAh%20(Blue)%202020-TripCurrent
Xtar%2018650%203500mAh%20(Blue)%202020-Charge
Conclusion
A good protected battery.
Notes and links
The batteries was supplied by Xtar for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
MRsDNF
MRsDNF's picture
Thanks HKJ. Beer
BaronVonEissler
BaronVonEissler's picture
Last seen: 1 year 4 months ago
Thanks for the review.
This battery is still not in your comparator.
You can't hide me from me.
HKJ
HKJ's picture
Fixed.
BaronVonEissler
Fixed.
Thanks.
The Unprotected Brand named Sanyo GA has significantly LESS voltage sag starting at 3A. At 10A the XTAR version can not even make a voltage curve. I expected the UP GA to be better but not that much better.
HKJ
HKJ's picture
Remember that protection adds a series resistor, usually with about 0.1 to 0.2V (Depends on the chip used) drop at the over current trig point.
Superstocker
Superstocker's picture
Last seen: 1 day 1 hour ago
Thanks HKJ! Looks pretty much in line with the Keeppower with just slightly less aggressive protection.
d_t_a
Last seen: 2 hours 27 min ago
Thanks! Hoping to see more reviews of Xtar batteries soon.
In particular I have the Xtar 4200mAh 21700 and the Xtar 800mAh 14500, and would like to know how they perform.
(The Xtar 4200mAh 21700 are quite good in my personal experience, probably just a little bit worse than Samsung 40T, but the size/dimension of the Xtar 21700 is slightly smaller = fits some 21700 flashlights that some other 21700s won’t fit into).
HKJ
HKJ's picture
Xtar has send me more batteries, but again only one of each type, i..e they will not be tested.
MountainKing
Last seen: 3 months 47 min ago
Thanks so much man…..Protection is the only feature I value and your reviews are invaluable even I do not post in each of your many threads…
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
