The E3 with XPL-Hi 5000k appears to be out of stock… Hopefully the code can still be active when the XPL-Hi 5000k becomes in stock (no Pre-Order allowed for this)
Interested.
I’d hate this, too. And an E3S is on it’s way to me, likely having the same problem.
I once fixed this problem with a piece of rubber glued into the boot (Olight M20 Warrior with a M20SX tail switch assembly). Worked well.
Yea, me too... :FACEPALM:
Ok, I received the E3S today. Even though I thought it was a dumb move because of the E3 button issues, I think the E3S's button is improved. I dunno for sure, but I think it feels better, not as much slop. Right now, my E3 is apart so can't compare side by side though. Could be it feels way better than the Amutorch TC500 because I received them together, and wow, the TC500 has really stiff buttons, tail and e-switch.
Interested as well
PM's sent to anyone interested
My order from Banggood, placed April 21st
for an Xpl-hi 4700 variant just shipped…
That was fast…
So the XPL HI 4700K in now in stock.
I ordered the 4700K at the same time and BG cancelled my order even after I asked to wait.
Amutorch E3 with code BGSM30% - $34.96 and $37.06
Hello, I am interested. Thank you.
PM sent
Only 2 pieces left
Haha… well, that didn’t take long. I got an Amutorch E3 in the mail yesterday. I did a runtime test today and after 25 minutes it got hot enough to desolder the ground wire on the MCPCB. The body had hit 75°C. I immediately aborted the test, but the “damage” was done.
On the plus side, I registered 3300 lumens at turn-on with a Molicel P42A and SST20 4000K’s. Much brighter than I expected. But then again, the light paid the price for it. Looks like a custom Anduril2 driver is in order along with some RGB aux (twas my plan all along anyway).
I know it comes with a boatload of heat, but seeing 3000+lm capability and Ra95+ and R9-90ish reaffirms my affinity for this emitter. More meaningful IMO is the relative CD/LM you get from them. I’m looking forward to whatever you cook up! This light is dangling on the edge of my wishlist - along with a few amutorches btw- just needing an efficient driver to pull it up. Series config mcpcb and boost driver is my hope
Well, on the plus side… the driver appears to be a Buck + FET so it could be pretty efficient if you’re not using Turbo (much). I was planning on measuring non-Turbo output but it got desoldered first. And while I had the iron out, I just went ahead and took the driver out so I could measure it. Once I get the new driver designed and am waiting on PCBs, I may throw the original back in temporarily to play with. I do know that when it dropped out of turbo, it went down to ~850 lumens. I’m not sure if that was the top of regulation or not.
Edit: disregard, this is a Linear + FET driver
Oh wow. Thought these where FET only, possibly linear, but never thought it was a switching circuit
Ehh, I’m a bone head. Please disregard that. It is indeed a linear circuit - there’s no inductor. The linear circuitry appears to use an extrenal op-amp, separate FET, and a large R050 current sense resistor. I really shouldn’t try to work and analyze drivers at the same time.
No worries… it’s not going to cause me any trouble. This light is a nice, very small hot rod. I would still recommend it, but with the disclaimer that when it starts getting hot, make sure to decrease output! Temperature regulation appears to only affect Turbo mode, not all modes.
