I would be considered a mentally ill person if I bought it
✌ FREEME - ASTROLUX MF05 SBT90.2 7000lm 3000m+ Thrower Searchlight - $390 (restocked) + Free Charger
I was unsuccessful in preordering this item, when I tried five hours ago, ten minutes after freeme posted "Deal is Alive". I did not have the top secret code at that time, and when I logged onto my BG account, there was no place for me to enter the public code that is posted on the first post of this thread, nor was there a place for me to enter my payment information. In my BG account, "Your order" tab does not show this item. Now, when I log into my BG account, the Preorder button is greyed out, so I am locked out of this deal.
So, this is one extra one for someone else.
What kind of 21700 battery it takes,so as to fit?Also,why they don’t sell all the batteries together with the light,so as to be possible to deliver batteries?You see,that it is not possible to deliver lithium batteries to some Countries.
21700 is used to power the fan.It should fit most OEM 21700.
It is cheaper and safer for air shipping. Getting your shipment detained by custom is no joke.
Any suggestion for a 21700 battery?What brand,flat top or button top, and what capacity and current capability?
It’s just for the fan, so high capacity makes sense. Current capability is not a factor. Brand is not a big deal.
Freeme will have to answer the rest based on what physically fits.
Is it just me or do the pictures on BG make it look like the reflector is slightly orange-peel textured? I must not be seeing it correctly, for a light like this.
Order placed. Thank you.
The reflection shows faint traces of the machining. It will not be mirror perfect when it’s this large.
I am out
To heavy, to long,venti
but still a great light .
7500 Lumen;Where they are come from ?
Regards Xandre
7500 lumens rating is pushing it. Maybe it's a higher bin? In djozz's test, his limit was 20 amps, but I don't see the LED peaking much above 5500 lumens at the max.
Actually I found a gen 3 datasheet here: https://drive.google.com/file/d/1JB32vdU60H_S6cMCuwjubYWGjUKUr-wI/view, posted by Jared originally, here: https://budgetlightforum.com/t/-/60686/25. djozz tested the SA bin and there's 5 higher bins on the sheet, in fact SA is the second lowest.
Yeah, Texas_Ace says the SBT-90.2 in the GT90 (uses similar FET driver and 8 x 18650 cells) maxes out at a bit over 5000 lumen. Lumintop also did an exaggerated lumen spec of 7000. I guess it’s just marketing.
Just ordered. Thank you Freeme!
Jason is probably right about the marketing spin.
I'd add a 10-15% for bump from our calibrated lumens to "manufacturer's" lumens. But still interesting a higher bin SBT90.2 should go from 5,000 to 7,074 based on scaling up the bin from SA to UB. SA to UB should increase lumens by 41.47%.
Thank you for your support!
Might get another next week
Thanks Freeme. I ordered one yesterday. It was the 18th light.
I hope they done a good job on the big Reflektor.
Robert
Thank you Freeme. Just order now. I was Number 23 flashlight.
I can see getting this one day but I dont feel like beta testing it. I bought the MF04S for $140. I would probably pay $30 more for the MF05.
