Soda can size 4x18650 flashlight recommendations
24 posts / 0 new
zarko550
Last seen: 7 months 1 week ago
Hi,
I’m looking for a can size flashlight, but something that can emit low brightness (sub 100lm). Also it would be great if it can have similar UI to that of a zebralight. I know about the meteor m43, but is it still being sold?
Thanks
peg matite
peg matite's picture
Last seen: 21 min 31 sec ago
Thorfire BLF Q8 or Sofirn version.
Great bang for your buck.
Miguel_79
Last seen: 38 min 41 sec ago
Emisar D18 and Astrolux MF01S
Yokiamy
Yokiamy's picture
Last seen: 18 min 5 sec ago
BLF Q8
Rexlion
Last seen: 3 days 17 hours ago
Q8 (“BLF” or “Sofirn”) is on top of the heap IMO; just get it, you won’t be sorry. Ramping interface is more fun that my Zebras and just as easy to use. Low is about 1 lumen (I can look straight at it) and high is 5000 lumens, brighter than car headlights. Runs on 4 18650s, but is able to run on just 1 if necessary.
== We save the planet from darkness ==
Th558
Th558's picture
Last seen: 3 hours 27 min ago
MF01S is nearly 700g so a bit heavy for pocket carry. The throw is pretty impressive though for a high output soda can light. If you want something more compact I’d say get the D18. Don’t own it myself but I’ve heard nothing but great things about it and Emisar in general. Q8 is good aswell but not as bright at max and more throwy…also much cheaper.
d_t_a
Last seen: 1 day 12 hours ago
size comparisons of some soda-can lights (some take 3×18650, like the Fireflies ROT66, Emisar D18 and Sofirn SP36. The others use 4× 18650, eg. the BLF Q8, Sofirn Q8, Astrolux MF01S, Haikelite MT03 TA). [Astrolux MF01S not in this group picture]
ROT66 gen 1 use Narsil, ROT66 gen 2 uses Anduril
Emisar D18 uses Anduril
Sofirn SP36 available in Narsil and Anduril (but different LED types)
BLF Q8 and Sofirn Q8 come in Narsil (but can be flashed to Anduril with a programmer device)
MF01S comes in Anduril
Haikelite MT03 TA comes in Narsil.
Both Narsil and Anduril allow a low mode, however, I can’t be sure if they can reach sub-lumens levels with multiple LEDs.
Taskulamppu
Taskulamppu's picture
Sofirn SP36 BLF Anduril: https://sofirnlight.com/sp36-blf-anduril-with-3-batteries-p0023.html
It’s actually 3×18650 flashlight but it has internal USB-C charging and amazing emitter options:
  • LH351D 5000K 90CRI
  • LH351D 4000K 90CRI
  • LH351D 2700K 90CRI
pennzy
pennzy's picture
Last seen: 9 min 44 sec ago
My pick also.
MoreHiCRILumens
MoreHiCRILumens's picture
Last seen: 1 hour 29 min ago
I kinda dislike 4×18650 lights just because they feel a little bit too big unless they are throwers. 3×18650 feels so much better when looking that floody soda can type of light and my favourite is easily SP36 Anduril with 5000k 90CRI. Great light pattern, good tint and price is a bargain.
Sirstinky
Last seen: 13 hours 13 min ago
Definitely go with 3 18650. You get the same capability as 4 18650, but maybe less run time. The Sofirn Q8 is by far the best for the money. The SP36 has high cri emitters, but the Q8 is brighter and throws farther. More runtime as well off 4P 18650.
zarko550
Thanks for the suggestion. I think I will go with the Emisar D18. I just need some more explanation on the ramping cfg on Anduril. Couldn’t find any info on how to set the ceiling. What I’d like to know is – can I click 150 times, so the ceiling would be the same as the turbo? You can see in the attached image.
Also another thing, is where can I find a screenshot between the floody optics and the default optics.
Thanks
ValuseekeR
Last seen: 4 days 6 hours ago
Don’t think you can really go wrong with any of the options discussed here, but have to agree with the other comments that the 3×18650 form feels noticably better for walking around and using the light than 4x, except maybe for those with huge hands (I wear a size large glove fwiw).
The Sofirn SP36 is an excellent light, especially if you catch it on sale.
Yokiamy
Yokiamy's picture
Convoy 4×18 ?
Sirstinky
4×18 is a great light, very good quality. Unlike the others, it’s a single emitter with 4P li-ion and a boost driver to run the 6v xhp70.2. It’s expensive for what it is (in my opinion), and for a little less money you can get the BLF edition SP36 with batteries and the Samsung high cri 5000k LEDs. It will make more light and have a better beam quality. Mayne not as intense or throwy as the 4×18 though. Plus I think the 4×18 is better for modding options.
richbuff
Last seen: 1 week 3 days ago
zarko550 wrote:
Thanks for the suggestion. I think I will go with the Emisar D18. I just need some more explanation on the ramping cfg on Anduril. Couldn't find any info on how to set the ceiling. What I'd like to know is - can I click 150 times, so the ceiling would be the same as the turbo? You can see in the attached image. !https://i.imgur.com/BQVICib.png! Also another thing, is where can I find a screenshot between the floody optics and the default optics. Thanks
Now we will set maximum light output in ramping mode to Turbo equivalent, then we will set maximum light output in stepping mode to Turbo equivalent.
First, click once to turn on the light. Next, four (4) quick clicks. The light clicks once to confirm that you have mastered this critical step. Next, the light flashes very rapidly, to indicate that right now, you need to click once to set the ramping minimum to the minimum. Do so, by clicking once, then wait and do nothing for four (4) seconds. After the four seconds passes, the flashlight will flash twice, to indicate that the flashlight will now flash very rapidly, to indicate that right now, you need to click once, to set the ramping maximum to Turbo. Do so, by clicking once. Then wait and do nothing for four (4) seconds. After the four seconds passes, the flashlight will go steady to indicate that now you have Turbo as maximum in ramping mode. Now turn the light off, to avoid entering uncharted territory. Press once to turn the light on, hold to max ramp, then double click for Turbo. The Turbo will not be any brighter than the max ramp. Yay!
Next, do the above in stepping mode. First, turn on the light. Then three quick clicks. Now you are in stepping mode. Now, four (4) quick clicks. The light clicks once to confirm that you have mastered this step. Next, the light flashes very rapidly, to indicate that right now, you need to click once to set the stepping minimum to the minimum. Do so, by clicking once, then wait and do nothing for four (4) seconds. After the four seconds passes, the flashlight will flash twice, to indicate that the flashlight will now flash very rapidly, to indicate that right now, you need to click once, to set the stepping maximum to Turbo. Do so, by clicking once. Then wait and do nothing for four (4) seconds. After the four seconds passes, the flashlight will go steady to indicate that now you have Turbo as maximum in stepping mode. Now turn the light off, to avoid entering uncharted territory. Press once to turn the light on, hold to max step, then double click for Turbo. The Turbo will not be any brighter than the max step. Yay!
Rev 22:15
zarko550
richbuff wrote:
zarko550 wrote:
Thanks for the suggestion. I think I will go with the Emisar D18. I just need some more explanation on the ramping cfg on Anduril. Couldn’t find any info on how to set the ceiling. What I’d like to know is – can I click 150 times, so the ceiling would be the same as the turbo? You can see in the attached image. Also another thing, is where can I find a screenshot between the floody optics and the default optics. Thanks
Wow! Thank you for the detailed explanation.
And about the flood optics do you have any experience – about the difference between the two beams?
Lightbringer
Lightbringer's picture
Last seen: 11 hours 17 min ago
Restating a bit, but:
BLF Q8 – floodier and warmer than the Sofirn, which I prefer.
Sofirn Q8 – cooler and throwier than the BLF, which I’m not crazy about.
Airpro DC7 – probably defunct, but like the Sofirn (as in cooler/throwier), lobotomised ramping UI but still fully functional with shortcuts to moonlight/turbo, built-in usb-c charging.
Sofirn SP36 – 3 cells vs 4 in the others, also built-in charging.
d_t_a
These beamshots just give an idea but may not be that meaningful since the distance they were taken were a bit close (the center hotspot of light gets over-exposed, meaning the light is supposed to go much farther if not blocked by the wall)
I tried to stay at a similar position (but don’t have a ‘marker” on my standing position when I hold the flashlights, and these are taken at different times, also sometimes I point the flashlight a bit higher or lower on the wall).
But the camera settings are always set to the same settings:
white-balance: set to “daylight” shutter speed: 1/10th second ISO: 800 aperture: f/2.8
1) Sofirn Q8 (4x XPL-Hi cool-white)
2) BLF Q8 (4x XPL-HD neutral-white)
3) Sofirn SP36 (4x XP-L2 cool-white)
4) Sofirn SP36 (4x LH351D neutral-white)
5) Convoy M3 (XHP70.2 neutral-white)
6) Haikelite MT03 TA Devourer (3x XHP70.2 neutral-white)
(I have another set of the same shots taken at the same camera settings but with shutter speed: 1/100th second, will need to collate them)
Frostcream
Last seen: 2 months 6 days ago
Thanks
Good choice. D18’s a boss.
I have a Thrunite TN36 Limited and a D18 SST20 4000k.
Similar output but the D18 is much lighter and smaller, making for a much more useable light in many cases. The high CRI is cream on top. As you can see, the D18 is also quite a bit smaller than the Q8, which I also have.
I use the D18 almost as much as my D4V2s (I bought 4 different Ti flavors of this very collectible light).
The poor Thrunite, while an absolutely excellent light, sits on my desk chilling most of the time. The Emisar is just more fun, more flexible.
zarko550
Thanks
Yeah my first choice was Thrunite before I knew about emisar. And yes I am looking for a high CRI flashlight – so aside from the UI the D18 ticks all the boxes for me.
Frostcream
Thanks
Fortunately, Anduril is ultra simple to use by default. It’s intuitive, and you never actually need anything more than the basics to use the light.
But if you want to go deeper the option is there.
Dalamar
Last seen: 1 day 19 hours ago
The tint and cct of sst20 is hideous unless you’re pumping like 5 amps through it and by then the R9 drops considerably. They tend to be green, and the cct is actually closer to 3850.
The ROT66 is available with Nichia 219B again. Buy that…or have someone build a custom sunlike/optisolis, but that would cost hundreds.
I only like high CRI. Collection:
Fireflies NOV-MU 21 4500k E21A
Fireflies ROT66 219B SW45 D220
Fireflies E07 Copper 219B SW45k? (odd/higher lumen bin with lower r9 and higher cct?)
Fireflies E07 219B SW45k
Fireflies E07x Pro sst20 FA4 4000k
Varmint removal:
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k  FB4 (3200ma)
Memes:
BLF GT94
Emisar D18 660nm SST20
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
d_t_a
I would like to try out the 4000k and 2700k option, but it looks like those options are grayed out now (they didn’t seem to be grayed out a few days ago, but I haven’t ordered that time).
Anyone have actually ordered the 4000k and 2700k SP36?
