Cable to reduce power output
4 posts / 0 new
ZoomieFan
ZoomieFan's picture
Last seen: 1 week 3 days ago
I don’t know what the name of the thing I’m looking for so’ll try to decribe it.
I have battery operated heating pad that put out to much power.
Reducing power with a step down cable could be an option, but I think they all introduce conversion losses.
Recently I was measuring the power draw of USB heated clothing and noticed the power is always at 1.3A at the high setting.
At medium it’s on for 1 second and off for a second. At low it’s off 2 out of 3 seconds. It think that method may be quite energy efficient.
I found switches on AliExpress that do exactly what I want https://www.aliexpress.com/item/4000286303936.html?spm=a2g0o.cart.0.0.c3...
But I’m looking for a ready made solution. A cable/plug with USB in and out.
Any advise on that?
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5, Xtar PB2S 5/5
Waiting for: (DQG Tiny) 21700 EDCs.
Lightbringer
Lightbringer's picture
Last seen: 4 hours 22 min ago
Looked, nuttin’.
If you don’t want to cut into the existing cable, you can get a usb extension cable (m/f) and cut into that. One splice, one snip, that’s it.
moderator007
moderator007's picture
Last seen: 1 week 6 days ago
Are you looking for something like this.
https://www.ebay.com/itm/15W-Adjustable-Voltage-USB-Power-Supply-Module-DC-5V-to-1V-12V-24V?
By reducing the voltage to the heater it should lower the current unless the heater is using a boost circuit.
Have you looked to see if the heater has some kind of current limiting circuit or was it just relying on low current alkaline batteries?
angerdan
angerdan's picture
Last seen: 2 hours 53 min ago
Any advise on that?
Put a USB hub inbetween. This reduces current to 0.5A (USB 2.0) or 0.9A (USB 3.0).
