1. The Longest beam throw model aims at the hunting and tactical&law enforcement
2. 3 version LEDs for option: OSRAM White, Green and Red light
3. The L17 is compatible with Remote Control Switch L16 (ARPS-R05)
4. Powered by 1x18650 battery (Recommend ARC18650H-310A with Built-in USB Port)
5. 5 brightness levels and 1 special Strobe available
6. Compact, Lightweight and extremely Durable
“The World’s Longest Throw 1x18650 Tactical Flashlight”
Quite a claim there, care to prove it? You wouldn’t even be allowed to put that claim in the UK market unless you could prove without doubt it was true. I doubt that is possible.
Good point. There is some competition out there. The Maxtoch Archer Osram has a tactical form and Eagtac has one or more tacticals with Osram.
Whatever, I going to buy this, big claims or not. I am enjoying my E10 and Acebeam are quoting longer throw on this light. I like the idea of having this size and throw with a 3700 mAh Panny in there for longevity.
This is best result I got when analysing 4 new Sanyo NCR18650GA’s
in a Xtar Dragon VP4 Plus. The other 3 were around 3450 - 3600mAh. Do you think that’s inaccurate? Could be…
What I could imagine is a customized 18650 cell with a slightly larger volume, i.e. larger diameter. Molicel M50A for instance does not match the standard size of a 21700 battery. It's more likely a "22700" battery.
