I’m wondering if that’s all green anodized but due to the angle looking blue on top.
I like that TwoSun knife, nearly shot one on ebay.
When I see the prices today I should’ve done so…
Those SRMs are not my cup of tea though, the tan handle/black blade one is looking like a $5 gas station knife.
Anyways, my knife budget is gone for this year
You can’t say that! That’s the version I’m curious about! :laughing:
I’m wondering whether that black acid washed finish adds any rust protection to a D2 blade.
My Bestech Lion with D2 blade developed a nasty rust spot while sitting on the shelf which left an ugly pit after removing and refinishing the blade. :rage:
It became a user instantly…
Nice plum color! :+1:
I wish Bestech used 14C28N instead of D2 in their budget line.
Well, my knives are users anyways, I very much reduced my “collection” so I have less than 10 knives atm.
Thos rust spots are looking familiar though, not from D2 but from Kershaws bead blasted “stainless” steels.
When storing a D2 knife it seems to be better to do it like in old times, wipe it with a thin coat of mineral oil and keep it at a dry place.
[/quote]
Nice plum color!
[/quote]
on wanting 14C28 on more budget knives. CJRB uses 12C27 on their Ria model, but D2 on the rest of their budget line.
Regarding the Texel; A friend wanted to buy his girlfriend a knife for self protection. I told him I was going to dye the Texel pink. He wanted a more unique color. A one of a kind color for a knife. He loved how it turned out, and bought it.
I’ve wondered the same thing about “blackwash”. I suppose anything would help? I’ve been a little sad to see D2 take over so much of the budget market due to the low corrosion resistance. I recently got a few spots on my Civivi Exarch, despite taking steps to prevent it.
I have my D2 knives shelved for the summer. I inspect them weekly and wipe with mineral oil as needed. A few weeks ago, I decided to adjust the pivot on my Exarch after wiping it down. I checked for blade play and forget to wipe again. Next week, I took it down and noticed a few hazy rust spots. Looking closely, I see that they were centered around a lone fingerprint on each side. Oops! That’s just ridiculous…
I prefer D2 to 8Cr13Mov at low prices (Kubey, Ganzo, PF, etc.) because you get a big increase in edge retention and only a small decrease in corrosion resistance. Dovetailing with another post, bead-blasting 8Cr13Mov can bring its corrosion resistance down to D2 levels. Like you, I’d much rather have 14C28N. I’m also okay with 12C27. I like 9Cr18Mov when done correctly, such as by Civivi or Real Steel. The Acuto 440 used by Tangram is pretty good too.
I was really happy to see CJRB using 12C27 instead of D2 on that one. Keep an eye out though. Artisan recently announced a new budget steel using powdered metallurgy: AR-RPM9. The Ria is one of the models slated to start using it. I don’t know anything about the properties but this could be a good thing.
That Plum Texel looks cool. I still like the lavender best. What colors have you experimented with for jade G10?
As far as self defense, folding knives are not a very good option. It would urge your friend and his girlfriend to do a little research. Real defensive encounters can be messy, chaotic, and quick. Having to get out a folding knife, successfully open and lock it, get a stable grip, and then use it with enough force to be effective without breaking the lock or hurting yourself can present a surprising level of challenge under common circumstances. Fixed blades or even pepper spray can be a much better option. Firearms tend to be the best choice but obviously, there are legal limitations in a lot of places.
I have a bunch of knives, and some were well over 100 dollars, but I can hardly tell any difference between the Ruike 801-sf and the very best of them, I would say the Sanranmu land 9103, 9104, and 910 in both colored scales is butter smooth as well. All my flippers are taken apart for cleaning and better pivot lubricant. You have 5 knives in that list, that deploy easier than the Ruike? I have never had any of them, except the Ruike and the land (the 9103 is now the 912) but they must nearly flip themselves, or the Ruike needs to be taken apart for cleaning, lubricating, and adjusting. The Ruike is still on Amazon for about 30 bucks, which in my opinion makes it the best value knife I know of. The Sanrenmu land knives were when I bought them at Gearbest, while on sale, about 10 bucks each, bought about 40 of them. It is not that the Land is not still as good, but the price has increased substantially where I have seen them sold. I think 21 dollars is the least I have seen lately. The Ruike you listed, which I heard was made at the same Sanrenmu plant, just have enough extra features to be well worth the higher price over the Land. Same caged bearing and stainless steel scales, but slightly better steel in 14c28n vs 12c27, a fipper tab and added blue accents at the pivot and pocket clip. The only advantage the Sanrenmu has is the fact that the pocket clip can be moved to the opposite side. Both brands have the quality, fit, and finish of much more expensive knives. I think the Real steel knives are also made by Sanrenmu. I think 4 out of the 7 knives you listed are made by Sanrenmu. The Lands were their budget brand, the Ruike were their mid-grade knife made for Fenix flashlight company, and Reel Steel were their higher priced knives. Sanrenmu also makes some of the Chinese made knives branded for and sold by Spyderco.
From my list of seven knives, any one of those knives could easily be someone else’s number one spot. Their all excellent thumb stud openers. My reason for putting the Ruike P801-SF in 6th place is only because the thumb studs are on the smaller size compared to the others, and I have failed deploying the blade on the first attempt, a few times, especially when my hand is wet. Most of the time the P801-SF opens the first attempt, and it opens like greased lightning, very sweet. If I use the flipper tab the P801-SF is awesome, and has never failed me. But, I was comparing thumb stud deployment for my list.
Anyone here ever come across Asher Knives?
I was really wanting to get one knife with CPM-S35VN steel. I have an S30V and figure it’s pretty close, but I just couldn’t let go. I had toyed with a Kizer… there have been a few models occasionally available at sub $80 prices at White Mountain on sale… and I was about to pull the trigger, when I came across Asher.
This particular model comes in at 3.2” in S35VN. Axis-lock design (probably my favorite, right alongside Arc-Lock). Thumb studs for forward flick action if desired. All at the pleasantly comfortable weight of 3.5oz. So many Chinese knives in this format (3 to 3.5” blade) hit 5oz or more. Looking it over in detail reveals so many nice touches. The standard clip annoyed me, but for just $5 more they offer a deeper carry clip with the bottom edge leveled off. The G-10 has a really nice texture. Steel spacer that’s floating with about 60% coverage (knives with no spacer always annoy me). Asher Knives are designed in Pennsylvania USA and produced in Hong Kong under US supervision. They’ve been in business since 2018. A small but respectable lineup, at very reasonable prices (there’s 20% off for orders above $100)…
OK, that makes sense, I have often wondered why there are thumb studs at all on the Ruike considering how well the flipper tab functions, it is a bit redundant. It does not stick out enough to snag on my pocket or anything though, so it is not obtrusive like some are. I am a fan of both the Ruike and the Sanrenmu. I know some do not like Sanrenmu because it is so similar to the Chris Reeves Sebenza, but to me that is not an issue. It does not claim to be a Sebenza, nor is it attracting the same customer base. Nobody that really wants a Sebenza is going to just settle for a Sanrenmu Land. The question I have is this, is it worth over 400 dollars added to the price for the titanium scales and S35VN? To me, it is not. I also would hesitate to actually use a knife I paid that much for. I do have some knives that were nearly 200 dollars, but even that is too highly priced for me to regularly use, and sometimes abuse them. That is the beauty of the Ruike and Sanrenmu, they function great as a cutting tool, and I do not hesitate to use them as beaters if I need to. Also do not worry much if I lose one…I have many of them. I understand the collectors that do buy them, I am just not one of those kind of collectors. I could easily afford a Sebenza, it just does not interest me.
They’re running on washers (I asked the seller). That’s not a deal breaker for me especially if the knife may see some dust & dirt during use.
Some nitpicking:
- If weight mattered that much I wouldn’t go for a folder with steel backspacer and full steel liners.
- The heads of the pocket clip screws are protruding. That’s usually a “serious” issue at $25 shipped budget knives. For $80 they could have done better.
The G10 handle scales look the same as the ones at my Land 910plus to me.
So except the blade steel I can’t see too much novelty here (I’m immune to the “designed in the USA” and “US supervision” marketing propaganda ).
For example in a smaller size the Kizer Fire Ant with S35VN blade and titanium handle looks a better deal to me.
@xevious
I would pick a Kizer any day over this “unknown” brand.
If S35VN and light weight is what you are looking for, the KI4419 can be had right now on AE for $62, weighs 2.85oz and has 4 aluminum scales colors to chose from.
Ki3404A3 Activ Bantam $82, Ti scales, 3.1oz
There are others in Ti/S35VN that can be had below $100.
This is good advice. Sadly, the international market for knives still has a lot of shady territory. Fake steel stamps are a persistent problem. Independent testing by LTK has helped to bust brands like Eafengrow and Fura for trying to pass off 8Cr13Mov, 5Cr15Mov, or worse as D2, S35VN, etc. This has really helped consumers to avoid getting duped. In Eafengrow’s case, they’ve recently responded with a pledge to go legit. (We’ll see if they keep to it.)
The other side of the coin is that this situation makes it hard for new brands. Until they are proven, caution is advised. Inexpensive knives in D2 can be a small gamble but I’d be especially cautious of more expensive knives claiming premium steels like S35VN. Personally, I’d wait until we have confirmation for any new brand.
Right now, we’re in a place where there are several Chinese brands that can be trusted. Kizer is one of them. Kizer maintains a good relationship with the EDC community and has authorized dealers on AliExpress. I have a few Kizers in my EDC rotation and I’ve been very happy with them.
