17mm is probably the most common as Tom E said. The easiet way is to make it as small as you feel comfortable working with then just change the pcb size to accomodate different size lights. That way the driver can fit many lights just by changing the pcb size in the design without having to go thru the process of designing a new layout.
I do not know any popular light with e-switch and 17mm driver. Why go small? Better change host with more space ;)). Tomorrow last hope. I will get FET with same specs only more powerful as is in original Tamagoshi schematics.
On BLF any light can become a host. There is plenty of lights out there that use 14500/AA with e-switch and a lot of 16340 lights also. Its your design, you design it as you see fit.
I have a Ultratac A1 using this driver with a XHP50.2 making 2000 lumens with a 14500 very floody. Its not a e-switch but I could have used a Sofirn SP10S, Thorfire TK05, or a Utorch UT01 for a host if the driver had been eswitch capable.. A XHP35.2 might be interesting in one of these host.
To name one (set), the Sofirn C8F family of lights use a 17 mm driver with e-switch. These lights are simple, powerful, and flexible, even available as a host, as well as triple LED's and singles. I got a few of these lights - outstanding modder's platform.
The C8 popularized the 17 mm size, as well as P60's (power switch), and even bigger lights like the HD2010 (power switch also).
OK, ill do 17mm later … if ill get running this schematic properly at all ;))
Is there temp regulation ? Have you measured the efficiency ?
Looks good. Nice job Quadrupel. A boost driver with good UI is not really available before this that I know of? What are the LED currents of the modes? I’m curious is the FW based on existing FW?
Another niche that needs filling is a linear FET driver with good e-switch UI. I would buy one for my H03.
There is overheat protection, you can set it manually, turn it on or off, but with off there is no turbo mode ;))
I have no proper tools to measure efficiency but should be much better than linear driver have anyway.
You can choose LVP level 3v; 2.5v and 2.2v
For reverse polarity using P-FET but , need to order new PCBs again with 3x3mm FET, because 2x2 is to weak.
The soft is advanced , but its not open source, i can not edit it. I’m just replicating schematic with some improvement in PCB design and trying to use more powerful and cheaper components and its not so simple , because soft is coded for specific hardware and sensitive to any hardware changes; ;))
Nice!
So at the end, what are the specs?
What are the available sizes and options to order?
Thx
Excellent job. The board looks really good, laid out well.
Nice!
Do you have it with a single mode 20w-25w version?
Also is that possible to order a version for a magnetic e-switch?
(Hall effect sensor - basically it is a switch that is connected to ADC)
I need one for my diving light.
Sorry, i don’t. Have no access to code, so UI as is. Its a simple e-switch … short click , click&hold…double click…. you know. Have no idea is it works with hall sensor switch ;))
Warning!
The author of this firmware is Tamagotchi”[1]“:https://budgetlightforum.com/user/29422 ”[2]“:Драйвер для питание XHP50 и MT-G2 от одного лития. | Мастерская: Tamagotchi и Rime , and he did not give permission for its commercial use.
Sure, no commercial use of FW. ( Боже упаси (креститься ) DIY only
Привет Фанарёвке от Stirlis (тот который послал льва и всех YLP адептов… и был забанен )
Дрaйвер для D10 совместимый с прошивкой Tamagotchi - уже … ( шутка - гекон нервно курит в углу )
Будет возможность купить драйвер без прошивки , которую сможете залить сами, через всроенный пого порт.
Boruit D10 Boost driver (in avatar) compatible with this Tamagotchi FW coming soon !
And i can sell some drivers (hardware) without FW loaded . You can flash ATtiny85 your self, since the driver have PogoPin port
Circuit and firmware link updated in first post . PogoPin Stick and 21mm PCB shared on Ospark and PCBWay.
Oh, hello, can you share your latest Firmware with community, please ?
A brief history in English. This guy Quadrupel aka Stirlis(on fonarevka) systematically violated forum rules and insulted forum members. After that, it was banned. And he decided to earn extra money on other people’s developments.
I strongly recommend do not buy anything from this dishonest person.
Not true. Tamagoshi shared FW to download for years. I made research and simplified circuit to be compatible with new generation of mosfets and diodes and made mine own PCB design.
To be honest i spend like 150$ on development and sold 4 or 5 drivers for 20$ each shipped .Id like to sell few more to get my money back . So why so jealous?
What exactly is not true?
