Ultimate LED Bulbs - Ultra High CRI - The Honorable Quest
Here’s an amazing tunable high CRI bulb of the “future”. Tech would need to trickle down to households but it’s an interesting read.
Update: I’ve replaced 6 bulbs so far because of major flickering issues (at full brightness or any range). Disappointing.
I’ve contacted their customer support to see if they’ll send replacements.
When you say full brightness is it still on a dimmer? I could never get the flicker out on my dimmer either and Lutron are regarded as some of the best dimmers for LED
These particular ones are on a Lutron Caseta dimmer. PD-6WCL i believe. I have no flickering or anything during dimming, they get really low before just simply turning off. They’re just randomly failing, probably crappy caps.
But it only allows changing CCT, which already exist. I wish it allows tweaking DUV also.
It can tweak to Duv as well and even adjusts based on LED age (by detecting fwd voltage) to maintain 1 step eclipse. It can dim through wireless commands or via in wall dimmer which detects waveform.
I love improved tech, but this sounds like it crosses a line into overly complex.
Are there any R7S LED bulbs worth recommending?
Interesting name. Feit. Fate. Ill fated? :person_facepalming: :wink: :smiley:
I’ve really been out of the hobby for lack of time since early May… Just moved into a new house and as any true lighting snob would, despised most of the bulbs/fixtures currently installed. Really wishing a truly good and affordable bulb becomes available soon. I still have a handful of Great Value bulbs waiting to get emitter swaps with SunLike 3030s. Also have really been desiring a truly good variable CCT (but not RGB) bulb. Ideally a smart bulb (circadian) that has a time/calendar/latitude programming maybe via BT or even one-time flashing via USB…
Gave the 600 lumen version of these a try, and it seems to have mad tint shift. The edges of the beam are outright orange on this set of them. I’m also getting more glare than I expected, but it might be just the beam being a bit narrower (36°).
That being said, found a 3000k Luminus 50W equivalent dimmable 90+CRI 40° GU10 claiming 71 lm/w (as opposed to the 80 lm/w that the 600 W Ledare claims) that seems to be pretty good.
Not seeing it online, but the model name in-store was Luminus Elite+ LED.
StarLike (tssss, it is the secret):
Crowdfunding of mass model of SunLike bulb (TRI-R) — Crowdfunding of mass model of SunLike bulb (TRI-R) updated 02.05.2021
I’d be very interested to hear more about these StarLike bulbs. Is this the next evolution of your SunLike bulbs? Still using the Seoul/Toshiba SunLike 3030’s/COBs?
Lidl have some E27 2700k 806Lm bulbs £3.49 for 2 pack. They are advertised as Ra >=97 but they are just an awful yellow hue, not the normal white/orange but more a bright yellow colour.
Livarno Lux branded
OWIM GmbH
HG06289A
IAN 339473_1910
I’d like to make a web app for this list that is a searchable, filterable list and includes spectrum data/charts. Right now I’m using the X-Rite Colormunki Photo, but I’d really like to be able to chart beyond 730nm. The much more expensive Sekonic meters only go to 780nm. The only competing product I’ve found that goes beyond is an aliexpress find for $1550 called the Hopoocolor OHSP350S that covers 350-950nm, or they have an integrating sphere setup with sensors that cover 200-1100nm, model HPCS6500, for the low low price of $7k.
Any options that I’m not aware of that would allow accurate, repeatable capture beyond 350-750nm?
Sekonic C-800 owner here. Even the best LEDs emit practically zero red light out at 780nm where the meter’s chart ends. And a Google search says human vision drops to zero well before that. But the good new is my bill for consultation is only $3500. You saved 50% :smiley:
Light outside of 350nm-750nm range is practically invisible to humans. For example, 730nm red light is 117x dimmer than 660nm red light for the same output.
Why do you want to do this?
Horticulture maybe?
It looks like the photosynthetic response and far-red horticulture stuff is within the human visible range too.
I just bought some Quasar Science bulbs from their clearance sale. Here are their measurements:
Quasar Science JDR light bulb 2000k 25deg 2101K 0.0026 DUV 96.9 CRI Blue light relative amplitude 0.06 79.7 R9 96.1 R12 90 Rf 94 Rg
Quasar Science JDR light bulb 3000k 25deg 3061K 0.0035 DUV 97.1 CRI Blue light relative amplitude 0.39 84.3 R9 84.8 R12 95 Rf 99 Rg
Quasar Science medium base filament 3000k 2766K 0.0003 DUV 96.8 CRI Blue light relative amplitude 0.35 80.6 R9 84.6 R12 93 Rf 99 Rg
Quasar Science medium base filament 2000k 2091K -0.0009 DUV 96.1 CRI Blue light relative amplitude 0.13 74.2 R9 90.8 R12 93 Rf 101 Rg
The JDR bulbs have positive DUV resulting in a yellowish/greenish tint. However, the lens can easily be twisted off to insert a sheet of Lee Minus Green Filter. A very easy fix. The filament bulbs are pretty much tintless, though I prefer a negative DUV which makes white appear whiter.
