Yes, Ausgezeichnet is correct, but the one who made it is never that much convinced and always finds a detail that could be made better
If the tartan micarta will work out well I must see if bronze is still the best underground for it.
Maybe a blue contrast or polished gold or even pink could look good.
Yesterday I did the dyeing, today Iām EDC-ing it but it is too heavy for everyday.
QSP Worker with carbon fiber/blue G10 laminate scales, RIT-died with āRacing Redā to turn the blue G10 into purple. I found the bright blue G10 too dominant, in purple it blends in more. And purple is my favorite colour
Is it possible to paint on Rit dye instead of dipping the scales in it? I was thinking of using frog tape, possibly cutting it into a pattern, tiger stripes or lines that get smaller as you go down the scale, just unsure if it would bleed past the tape or work at all once you dip brush in the hot mixā¦even a splotchy multicolor Jackson Pollock type application might be coolā¦.er I have to many knifes that are black, one colorful wont kill me
There was never a Chill in a better steel afaik. Iād like one in Sandvik 14c28n for example, still budget but much better than 8Cr13/14MoV or D2, especially with Kershawās beloved bead blasting which even makes 8Cr rusty.
So no sprint run, just scales made by myself 4 1/2 years ago (as the timestamp says)
Excellent flipper on bronze washers, my slim Boker Urban Trapper would be more stable on bigger bronze washers as well.
Thank you. Well, I donāt know, especially due to the fact that the Boker UT hruns on ball bearings and would need some fitting washers to fill that gap first.
It doesnāt matter enough to me to search for bronze washers.
Iād look for them on ebay - phosphor(ous) bronze washers or at shops like usaknifemaker.com
As much as possible we should forget those guys that misused a Asian sign for the sun and prosperity and good luck.
+ a slew of other meanings depending on the cloture you focus in on, but those Germans once misusing it we should for get about, and only pull them out of the history books when someone need a scare.
