SKV89, thank you for sharing all those measurements.
I was under the assumption that 16x E21A mules would be limited to 7.5A CC only, and there would be no direct drive, because it isnāt safe. I am surprised that direct drive is enabled. Are you sure it is safe to use Molicel P26A for this?
I cleaned the contacts, and actually very lightly sanded them to make sure thereās nothing blocking the connection surface, but the flicker is still there. Now, when I say flicker, itās very subtle. Itās only really noticeable when youāre not moving the beam.
I tried varying the floor from 1/150 to 3/150, and the flicker is evident on 1/150 and 2/150, as expected.
When moving it to 3/150, though, itās as if the very low level flicker from 1/150 and 2/150 is still there, but is masked by the higher brightness of 3/150. I hope that makes sense.
Itās tolerable, I guess, but itās also annoying when I notice it, and just knowing that one of my favorite lights isnāt stable at moonlight drives me mildly nuts since I use it every night.
Do you think thereās anything on the code side that could be done to eliminate this? Iām not familiar with the coding at a hardware level.
Thanks, again.
Edit: Would increasing the clock speed at level 3/150 make a difference? Or, maybe just disabling dynamic underclocking would be a reasonable test.
Yes, it makes senseā¦ and is quite possibly whatās happening. Thereās going to be a little bit of ripple. Letās say thereās 1 unit of ripple. At a brightness of 2, itāll be pretty noticeable as it ripples from 1 to 3. But at a brightness of 100, itās not noticeable since it only goes from 99 to 101.
Lowering the clock speed threshold level might help a little, or it might notā¦ itās hard to tell without trying it on affected hardware, and I donāt have affected hardware.
Regardless, I sent Hank an idea for how to improve the low levels. I also posted it here a few comments ago. I donāt know if itāll happen, but itās at least being discussed.
Iāll most likely test switching off dynamic underclocking or lowering the threshold, but it will probably be a week or two. Iāll be sure to report back.
Just got my KR1, but just isnāt able to turn it on. Iāve tightened both head and tail of the light as much as I could and cleaned the sleeve from burrs using paper. It seems to be doing the factory reset just like this:
If itās doing the factory reset, Iād say the inner tube is making at least some contact.
Did you also clean the contact surfaces (ends of tubes)? Generally, I clean them with alcohol on a cotton swab, but the contact surfaces of one of my KR4 tubes had to be very lightly sanded to fix a connection problem.
Also, on the KRās I think itās best to carefully tighten the head first. Once you get it working reliably, leave the head alone for battery changes.
That means the outer tube isnāt making contact. It might help to make sure there is nothing blocking either end of the outer tube, like stray bits of anodizing which might not have been removed, or anything else stuck on the ends of the tube or the outer contact surfaces in the head or the tail. Also, try to make sure the big spring in the head isnāt getting in the way.
Then make sure to tighten the tube to the head before tightening the tail. It shouldnāt need to be super tight.
Also, totally off topic, butā¦ Itās not often I see āPosts: 1ā on an account 6 years old. How did that happen? Often times, people will respond with a āwelcome to BLFā message when someone makes their first post, but Iām not sure that works when so much time passed between creating an account and writing a first comment.
Trakcon - have tried cleaning with your method, also sanded the inner black tube per Hankās suggestion. Still no luck unfortunately.
ToyKeeper
- as far as I can tell, the contact surfaces on both head and tail caps look fine, nothing seems out of place with anything obstructing contact. Was inserting battery from head earlier, have now moved to inserting from tail.
Yeah, was still in college when I created the account. Had other priorities back then. Now Iāve got a job/money to spend on hobbies so here I am after a D4SV2.
Am currently in contact with Hank to sort it out. Thanks guys
