m4d, are you affiliated with the newer Firefoxes 5 HID? If so, is there a GB here on FF?
I would be interested in the Fire foxes FF5 GB too. 10k lumens at 2000m throw with a relatively small size is just incredible. I found some photos of it on google. That tint is just gorgeous (100CRI?). I doubt LED flashlights will even reach that kind of performance in another 5 years.
i already shared my desl for the FF5 ;)
FIRE-FOXES FF5 XENON HID 10000LM 2000M (4300k/6500k)
(to my knowledge only Neal sells them atm)
Finally got myself a GT Micro.
Love the design and the size, with my Shockly 1000 5A its amazing. The throw is just epic for something ssssoooo small - Pretty impressed with the mini that arrived at the same time too!
Unfortnatly im not really one for the ~70CRI Cree emitters. I really want to try my lovely pink 80CRI XP-L HI 3000k that i put in so many lights.
I do apprecaite the 4000k, but a rosy 5D it most certainly is not.
THE GLUE ITS DRIVING ME NUTS. I dont understand why they did it, the Mini just unscrews!
I tried my usual 2 x strap wrenches but i just cant get it off.
SUCH a waste of an amazing light. I might have to pickup the Osram one though as thats another emitter i wanted to try.
Does anyone think that heating it up with a heat gun might help?
It couldnt be too hot as id have to still put the rubber strap wrenches on it. I dont really have much in the way of industral vices either, just my cheap little soldering ones.
The GT Micros I bought from last year definitely is the 5D rosy tint. Not sure if it’s a different batch of emitters as they vary from batch to batch.
Btw, does anyone know what driver the GT Micro with the Osram CSLNM1.TG uses? I’m wondering if using the Vapcell H10 10A cell will kill the driver if it is not limited to 5A.
I don't believe there's anything special for current limiting, unless they used reduced size LED wires or/and made them longer. I'm not sure - I don't have one, but doubt they changed the driver.
the GT Micro osram version is currently out of stock, any idea when will it be available again?
In
i try to find out
What cell is everyone using ? The Vapcell 14500 1000mah Gold ?
Thanks
I got the KeepPower 14500 1000mah battery with my purchase and have been really with these cells so far
Thanks
Shockly 1000mah 5A. Cant fault it in any device, its certainly brought the 14500 up near the level of the 18350.
Still think the 2000mah 18500 is the sweet spot for a small EDC though.
Plain ol’ EBL 14500 since I got it. Tried a Vapcell no-number, just 650mAH/7A cell, but didn’t measure tailcap current or anything.
i read on FB copper micro and edc 18 is on its way…
micro copper will get a osram
Hoping they’re optimize the reflector of the Osram-based GT Micro. Seem to recall seeing some report that it’s not perfectly focused if GT Micro (XPL-Hi) then simple
LED swap to Osram NM1?
To be honest, i struggle with the focus on an aftermarket XP-L HI, cant remember before i swapped it though. (Yes i FINALLY managed to get the bezel off!)
The Copper Micro is on the Lumintop website now, i got an email.
I think id rather just get another Alu myself, with native Osram when its available.
Its quite an amazing light. I cant think of anything that has a large and deep reflector as this and still fits in your pocket. TBH though i would prefer a slightly wider battery, eg. 18500 withut having to step up to the Mini.
Will the ORBTRONIC 14500 1100mAh have enough amps to power this on turbo?
