Just received a Nichia FW1A, must be from new batch because can confirm has new reflector with wide spacing, a little disappointing to be honest.
Disappointed to learn of the reflector issue. Lumintop are total cheapskates who have no pride in the quality of their products.
Yup, hugely disappointed. Along with the smushy, doomed to fail switch on the GT mini, its unlikely I’ll be buying another Lumintop product.
large hole at base of reflector with small LED, is not a good match
some possible ways to improve the beam
1. Use a wider LED such as the LH351d
or
2. move the small LED closer to the reflector, by creating a 0.5mm thinner centering ring
What about filing down the back of the centering ring?
I could use a bigger LED, but I was hoping for some throw in a little pocket light. I was expecting more than the S2+ since the reflector is wider, but it’s actually less throwy than the smaller S2+ reflector.
I avoid modifying the original part
fear of breaking
I sand down one these alternative centering rings instead
so I can go back to stock if all fails
Amazing how they took the FW1A, which I’ve seen praised numerous times for the amount of throw it provides in its size, and ruined it so quickly.
I have a couple extra of those, I’ll experiment and report back.
I’m glad I got a FW1A before it was changed. It’s one of my favorite lights.
Anyway, hopefully someone can post test results for the modified version. I’d like to see the before/after data.
It is really disappointing how they compromise these designs.
“We ran out of reflectors for this model”
“Just use the reflectors from a different model”
“But they won’t fit properly, they will looks stupid and give a bad beam.”
“LOL, who cares. If the customer complains, tell them they have to pay to send back to China. Nobody ever does”
There goes my idea to get a FW1A for a lume1 driver…
It would have been my most used light but now is my least used. Please make the old reflectors again and let me buy one
Yes, for XPL-HI or SST20, until we know IF throw numbers have changed we know nothing. The one picture posted of the beam pattern looks pretty similar to the old one.
I had an OP reflector the correct depth, but smaller diameter, from a cheap brass light that I converted to TIR. A little ugly, but it fits. The centering ring holds it in place well enough for now:
Beam is better (camera is not):
I also have one with the approximately correct diameter and depth on order from KD, so I’ll try that when it arrives. Shame this is necessary for an otherwise excellent light.
Chabuduo, dammit.
A while ago, I ordered a 1A warm and was sent a 1A cool blue-white.
I guess I will keep it, it appears to be the earlier model.
I’ve found that the Convoy S21 reflector is a acceptable fit for the FW1A. I converted a 3A to a 1A a few weeks ago and the conversion was not difficult, but finding a suitable reflector was!
My solution was to place a copper spacer of approximately 3mm between the shelf of the FW3A and the MCPCB, this left the perfect amount of space for an S21 reflector after its outside bottom rib had been turned off to allow it to fit inside the head.
I do not believe that it has as much throw as the stock reflector, but it makes a fantastic beam with a LH351.
I did this same thing last year sometime. I made my own bezel out of 7075 Al and turned the reflector down, removing the bottom rib (or two?) and putting a clean taper on down to the emitter hole for good wire clearance. I then started sanding the lip of the FW3A head (at the bezel threads) to achieve maximum focus and keep the Al-Al contact, but went too far :person_facepalming:. Now I use a centering ring and there’s a small gap between the reflector and head and consequently the bezel…
I’m running a sliced SST20 4k and am generally pleased. Output is pretty low but beam is great, albeit a narrow hotspot. Been looking to put a sliced 3500K LH351D in for a while to get a broader beam, just never got around to making a digikey order.
I’m going to try and source a SMO reflector from the new S21B and see how that looks next. I’m currently getting 16kcd@1m (measured at 5m). Very clean beam and minimal angular tint shift. Only the slightest corona.
Wow, that is much more ambitious than my project. I considered taking some material off of the FW1A bezel instead of building a spacer, but the bezel I purchased is stainless and I didn’t want to have to work with anything that hard. I don’t mind having a little extra mass for the thermal capacity anyway.
The smooth S21 reflector is what I’m using. It makes a great beam with a domed LH351, I had considered dedoming, but I was happy with the throw so I left it alone. I did dedome a 2700k Samsung in my Thrunite T10 Ti and I’m really happy with that one, it got a little pinker and gained a bit of throw.
Today I had some time and tried getting the stock reflector closer to the board; it removed some artifacts but the throw still is not what it should be for a reflector this size. I also tried installing a slightly bigger LED (219B sw40), which works better with the original spacer but of course the throw is even worse. Frustrating.
One thing I noticed was the MCPCB is super thick, like the one in the FW3T. So if I find a slightly longer reflector I might be able to get it to fit with a normal 20 mm MCPCB.
