Just shine it against the wall and measure the size of the hotspot. Then replace it with the other optic and compare. The difference in hotspot size is very significant so it is easy to tell.
K. Thanks. Wasn’t sure if there would be a difference in looks as well.
Got mine today with a 219B emitter. However, i noticed something weird about it, the light flickers for a few seconds on max ceiling. Do i need to return this one? Thank you!
Those 219b emitters don’t like being driven too hard. I actually kept my max ceiling set low as they will overheat and actually put out a purple tint that won’t go away when over driven.
I hate to be the bearer of bad news but the damage may have already been done. It happened to mine initially as well.
they should not “overheat”, are you sure it’s not just the anduril blink telling you it’s at the top of the ramp? I dont remember if the stock E07 firmware has that or not
Hi! I know the quick flicker when reaching the ceiling ramp and the floor. However this one is a flicker for about 3 seconds then it disappears.
You should probably clean everything with alcohol (springs, threads, driver ring, and your battery + and -)
If you are using 18650 make sure to use flat top with their black adapter. If you are using 21700 make sure it is flat top and not too long (Chinese brand battery sometimes are while OEM brand is shorter)
fireflies E12
Nice looking light.
That thing better be factory spring bypassed. Wonder what the head with is. Maybe 45mm?
Once I told them to make and E09 and they made an E12 instead I’m not complaining though.
Looks like they just stuck the ROT66v2 optic in an E07. So it should be the same bezel diameter as the ROT66.
Does seem like it. That’s means it’d be 50mm. I’d prefer something smaller with less throw. I like the floodier beam profile on my FW21 Pro.
This guy problem solves
i wanted to buy this one…are the owners here happy with this one?its a bit older model….
I’m very happy with mine but there’s supposed to be news of a gen 2 coming soon. Hopefully with a better optic.
really??? oh…again i have to wait:)
anyway i heard about 20 sec of turbo for xplhi…
All those pics but none auxiliary led
If you can use turbo for much longer than that, the turbo isn’t high enough IMO!
I can turn it down myself (with the button or with the software) if I want a longer running level of brightness. Turbo is for momentary use…that’s literally the whole point of having a turbo. Like nitrous on a vehicle. Use it too much and it’ll probably blow up, but it’s there for short bursts when you really need it. :sunglasses:
I was happy until it broke - switch doesn’t register clicks. I’ve contacted the company about the issue. They asked me to provide video evidence, which I did and then I got ignored. Not recommended.
Just go buy Emisar/Noctigon from Hank. I’m sure you’ll be more satisfied in the long run.
